8pt Cage Installed 56k DEATH
Tyson does great work...
I saw your car at PAF when I was took my car down to get Tyson to do custom SFC's, CM subframes only added 10# to my car, the man is a metal working genius...
Just wanted to say, great setup, now just get the power to need it...
I think some of you need to actually read a NHRA rulebook before commenting
the car has all the required points to certify to 8.50. there is alot of confusion with the "10-pt" cage name. The front pillars are 2 points, hoop is 2 points, back down bars are 2 points and the kicker bars are 2 points. This is only 8 points but has all the NHRA required bars
The coating rule everyone is talking about is the following:
powdercoating is NOT plating. Plating is submersing the chassis in a tank and electrodespositing on the substrate. powdercoating is "painting" a powder on the chassis and melting in an oven.
Plating of chassis prohibited for all cars manufactured after 1/1/2003; painting permitted.
Race your car!
[QUOTE=Fireball]I think some of you need to actually read a NHRA rulebook before commenting
QUOTE]
what about the 2 other bars that usually come off the main hoop and go to the trans tunnel? Those are not normally required? I could have sworn that when looking on the nhra site the pics they had of rollbars/cages in there had those bars shown.
EDIT: I see the bars I am referring to now with the cage outside of the car, but I don't see them in the car.. could be the pic's/my monitor though, I dunno.
If not, my bad and I'm sorry for the confusion
QUOTE]
[QUOTE=JL ws-6] The rule isn't that they go to the trans tunnel...If you look at the drawing of the rollcage in the rulebook,
http://home.comcast.net/~tfranklin55...cage_rules.jpg
the bars you are referring to are bar "D". The requirements for these are
There is no subframe structure in the tranny tunnel. if you look at this picture
You can see the "D" bars (what I referred to as the kickers) in the picture
QUOTE]
QUOTE]
1 1/4" x x058" CM or .118 MS mandatory when main hoop welded to plates on floor; must be connected to subframe.
Originally Posted by LS1SpeedAddict
I thought you would like that.
When I asked him about fixing that issue he was like "thats going to be tough to do, maybe you could get someone to cut the seat around the bar" ...WTF !
I cant believe Ash is taking her car to him
Glad your happy with yours, I'm sure you paid through the nose for it.
Looks good.
Race your car!
[QUOTE=Fireball]
I see those now, I didn't see them in the pictures of the finished cage, probably the angle the pic's were taken just kinda hid them I just know that most of the cars I see have those bars connected to the tunnel... not that they have to connect there specificially.
