29.5 x 10.5 Question
Ok so im going from a 28 x 11.5 ET Drag to a 29.5 x 10.5 Hoosier Drag on the Trans Am, Its Already Clearenced for the 28's so how much more am i gonna have to cut out or hammer in??
I am going to the wolf tubs and 315/60 15 radials. I am wondering how much to narrow the rearend with a 5inch back spacing wheel to tuck it and slam it down like that.
LS1, i'm going to run that same radial or a 28x10.5 depending on location etc. I am minitubing and narrowing 3" per side running a 15x10 wheel it would be a 5" BS, and with a 15x12 wheel a 6"BS. Only reason i'm using the 12" wheel is it makes a larger contact patch.
Well like i said im running out of gear NA with my 4.56 gears, and on the spray i know im gonna MPH alot more so its either make the tires fit or change gears and i will eventually need the tires anyway.. OH and i think i will get them to fit without narrowing the rear or mini tubbing... and yeah 8's by the end of the year, i just need to set some new records first
