Qa1 settings adj.
Qa1 settings adj.
hey wanted to know if someone has the same set up as mine. auto with 4000 stall with spray. Rseries fronts and back 275 springs
370 motor. running 15 tire m/t et drag. What setting are you putting your shocks on at the track just bought mine and would like to know where to start at on the track. Running a umi chasis mount torque arm
thanks guys
thanks guys
Fronts 0
DR 7 PR9
This is generally the settings I used. Each car is different and you will have to go by trial and error until you find the sweet spot your car likes. Don't despair if at first you don't hook, just keep on trying. Also the track conditions come into play and each track is different.
I used the settings above today at the track and my first three sixty foots were 1.53 to 1.55. After that, the sixtys went away. I could have change the settings trying to get a better sixty but I left it the same because I was just having a good time.
DR 7 PR9
Originally Posted by dnkynrbk
as far as tire running m/t drag with 14 psi 15 inch tire
LS1Tech Co-Founder
Hmmm...
Tire size?
Raceweight?
QA1 R shocks or the other ones?
I'd say 2 in front, and 6 in back. If the car spins I'd go 1 in front. If the hooks well i'd try to get 7 in back later.
With a 150 shot, h/c, 3300 raceweight of the brake, 1 in front and car has CE shocks in back on the 50/50 setting so like 6, 28x10.5S at 12 psi, went 1.38 on a cold track. Car went 1.48 on motor. I can see a 1.3 if the track is working and your car is not like 3700 lbs.
Tire size?
Raceweight?
clarification pls.
are these settings clicks from all the way out, loose (counter clockwise) as a start point or the other way, backing them out..
just thought it would be helpful.
peace.
peace.
LS1Tech Co-Founder
Righty tighty, makes them stiffer.
You know you have them loose you can move the front end up and down with your arms.
@ 3500, I'd say a 1.40-1.45 unless you make big power.
You need someone to watch what the car does off the line.
