Installed an Odyssey PC680 today
The main reason I got the lightweight battery, aside from weight savings, was because my stock battery hold down broke, and they didn't let me pass tech the last time I went to Maple Grove because of it. So, Today I made a secure mount and installed it, this thing will not move at all...
I don't see this one failing the tech. inspection...
http://www.1slowformula.com/images/pc680_mount.jpg
http://www.1slowformula.com/images/pc680_mount2.jpg
What do you guys think?
Everything that I have read says it doesn't effect it at all...
BTW, be carefull you that you don't leave your bottle heater on with the car off and this battery though...
I have the same battery when I go to the track. If its your DD be sure to carry some jumper cables. The reserve on it is only 24 mins. So it drains pretty quick. -Mark
Race your car!
I made a mount that's similar, but it's just a single strap without the ones you have wrapping it. I have a single big screw hlding it to the rad. support as well, and mine passed tech. It's a one inch wide strap, and I ground the end of the battery a little so it sits in between the ribs on the battery itself.
Yours is alot more sturdy looking then what I did, I don't see youhaveing any problems with that.
I keep a battery tender on mine too when it's in the garage, and I don't have any problems with the car starting, and when it's warmed up and gets parked at car shows etc it's been fine as well.
I won't hook my bottle heater to it though, when I go to the track this summer with the kit on I'm gonna hook the bottle heater up to a jump pack while I'm in the lanes.... I know there's no way that little battery will last if I'm trying to run a heater off it.
Yeah it's in there pretty tight...
But I wanted to be sure of that since I was soo pissed to get all the way to the track just to have them turn me away for something that stupid...
Thanks guy's, I did this a while back, and if I recall the mounting bolts are at least 3/8, well the 2 in the front ar the rear is the stock mounting bolt since this still sits on top of the stock mount...
black_z - at least 20# weight reduction, but would need to weigh it again to be sure, it was a few months ago when I weighed them...
*** EDIT ***
I just looked it up what I used, and they are metric 10 X 25mm and that equates to roughly 3/8 X 1" bolts. So I'd say they were legal, and I have never had a tech inspector give it a second look...
*** EDIT ***
"All Motor 9 Second club member"
We daily drove that same battery for 2 years and never had an issue and never even came close to it not starting.
I swapped to the battery in this link once we added the 408 stroker with 11.6:1 CR and it hits like a full size battery. We bracket race to so there is a lot of stopping/starting with just a few minutes between the starts/stops. This one is a bit pricey, but it's a keeper. The Odyessy is great for a HC car though.
http://www.brailleauto.com/ProductCa...=2&idproduct=1
I love the mount. My mount was no where near what you have, but I never had a serious tech inspection either. You did good!
Originally Posted by James Montigny
Anyone up north using these in the cold ?
I'm not sure these will crank over a 11.2:1 motor in -30*
