Need directions on how to remove pass. airbag.
Re: Need directions on how to remove pass. airbag.
disconnect the battery and let sit for 30 minutes. then unplug it (big yellow wire) under the console. remove the glove box. pull the dash back and remove the 4 nuts from that bracket holding the air bag in there. pull it out as one piece. i think this is right, its been awhile.
Jerry
Jerry
removal of passanger airbag
OLD THREAD!!!
first off my car is a 94 camaro z28...
is this correct did it work???
where is this yellow wire???
did it throw any warning lights codes???
do u have to remove upper dash pad or anyhting or can it all be done from the bottom??? if i get this right u can do it without removing the dash it will slide through the glovebox opening???
thanks
daniel
thanks
daniel
Originally Posted by DOUBT IT
I've been looking at doing this also, so c'mon, did it work? Or am I gonna have to take my dash all apart...
Mod seems very ricey if you're not building a full-out race car. If you wanna go faster for cheap, buy a nitrous kit.
Originally Posted by Mike 01WS6
You're taking your airbags out in a high 12 second car? Why?
That and I have had some bad experiences with air bags myself.
I took mine out of my '96.Unhook the battery, then I took the top pad off, the glovebox out, unplugged the yellow wire, and loosened the dash on top, so I could pull the dash back. just be careful how far you pull it, or it will break the frame. you have to take out the 4 screws on top that holds it in, but I found it easier to take the 4 nuts off the bottom of the bag, and pull it out as 2 pieces.
