Drag Racing Tech
got into arguement on tire PSI for radials
Old 11-11-2007, 11:28 PM
Taubr Unit's Avatar
Default got into arguement on tire PSI for radials
Got into a debate today at my work about tire psi on MT et street radials. When i was testing my car i had them set at 20psi (fairely new tires) and i couldnt get them to hook even on cement and a lot of VHT. So i said i need to dial my car in better and they said to drop my psi down to 10/12psi. So i said i didnt want to cause radial tires work with more psi compared to a drag tire with a wrinkle wall. Went back and forth for like 20 mins. Sooo.........
WHAT PSI ARE YOU GUYS RUNNING ON YOUR RADIAL TIRES???
Old 11-11-2007, 11:29 PM
chrismorales75's Avatar
ran my 275 60 15 @ 18psi
Old 11-11-2007, 11:47 PM
xpndbl3's Avatar
seen 16-22 pounds depending on power and vehicle weight.
Old 11-11-2007, 11:50 PM
ZFan88's Avatar
I hooked best at 13 psi
Old 11-11-2007, 11:52 PM
TwoFast4Lv's Avatar
I have never really ran Radials lower then 16Psi with any luck. Lower then that and they just cupped and spun. With the 275/40s-17s MTs they liked 18-20psi. I have not got the 325 to the track yet, I just got them.
96lt1m6's Avatar
usually 22-25 psi on real radials
16-20 on Drag radials
12-15 on slicks/ET streets
minytrker's Avatar
18-22psi on 325/50/15's for me.
Old 11-12-2007, 12:43 AM
Pontiacerator
RevGTO's Avatar
At my modest bolt-on power level, I can hook at 20-22 depending on conditions. A harder launching car would call for less. IIRC, MT recommends about 16-17. I wouldn't go much less than that on them.
Old 11-12-2007, 01:49 AM
Restricted User
Smokin87TA's Avatar
I usually ran around 16 psi, depending on what i was looking to do and what surface i was on. Lowest i ran was around 13psi on the street, they were screwed to the rims, i would not go lower than 18ish if not screwed.
Old 11-12-2007, 01:56 AM
silverZ98's Avatar
275/60/15 i had luck with 16psi hott
Old 11-12-2007, 03:27 AM
EPP
EPP's Avatar
We got a 1.29 60 ft on 325/50/15's at 17 psi. Bob
Old 11-12-2007, 04:57 AM
Race your car!
JL ws-6's Avatar
I ran the goodyear 275/60's at 18.5 and had the best luck. I tried them down at 14, and up to 22, but the 18.5 seemed best for my car. 3450 lbs though, so it's a little heavy.
Old 11-12-2007, 06:36 AM
ThoR294's Avatar
i ran my radials at 23psi. worked fine for me
Old 11-12-2007, 07:36 AM
70Stang's Avatar
18-20 1.29-1.39 60' 325s
Old 11-12-2007, 07:59 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,110 Likes on 728 Posts
17 psi, and that was a 1.35 run.
Old 11-12-2007, 08:21 AM
Retired Street Racer
Matt D's Avatar
17 psi hot, 1.55 60 fts with 330hp @ 3175 raceweight.
Old 11-12-2007, 08:41 AM
cam
cam's Avatar
13 psi MT et street radials 275/40/17
Old 11-12-2007, 11:25 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
17-18 psi on a 275/60/15 for a 1.52 60 foot.
Old 11-12-2007, 11:29 AM
gator's 99TA's Avatar
i have messed with 15-22 psi. i have hooked at 15 psi and at 22 psi. the problem lies is at low tire pressure, it tends to shake and hop real bad if you cant hit it with a ton of power.
overall, i have had much more sucess at 20psi. my car has gone 1.37 60' on the 325 radials
Old 11-12-2007, 11:36 AM
pmbmax's Avatar
315/60 m/t had best at 15psi anything lower have tire shake run my 325s at 14 to 16 with no prob all pressure while cold. can pull low 1.30 s on a dirt road car is 3500 lds but have had alot of convertor issues so may have better 60 with new chance i just put in.
