Drag Racing Tech
Wolfe 6pt Roll Bar
Old 11-15-2007, 10:48 AM
code4's Avatar
Default Wolfe 6pt Roll Bar
I just ordered a Standard CM 6pt roll bar (weld in)
Can anyone here that has installed these tell me if you had to pull the head liner out to weld this in & paint. I am pulling all the carpet, console, & plastic.
Any tips for cutting holes in rear plastic over fenders so it is perfectly aligned with the bars?
Old 11-15-2007, 11:24 AM
chrismorales75's Avatar
It's easier if you pull it out, but you can get around it if you use plastic when you paint and a thin sheet of metal and piece of damp card board stacked together covering where you're welding above to deflect the sparks.
As far as getting the hole where it needs to be there are a few ways.
But this is how I would do it.
remove the speaker grill and when you are ready to mount the rear bar tack it in with a small tack top and bottom, have the rear plastic on without the speaker grill, have the bar mounted where it will go, take a piece of card board and cut a slit 1/2 way down the middle, then cut a hole that will fit tight around the bar, then you make marks on the card board and marks on the plastic where you can line it up, once you have your pattern remove the card board and bar and replace the speaker grill, then use your card board template, align the marks and then trace the hole and use a dremel to cut out the hole then you're good to go.
Old 11-15-2007, 09:53 PM
code4's Avatar
Thanks for the info. I think the headliner is the only piece of the car that I haven't removed before. I'll see how hard it is to remove, it's a hard top car.
So the rear bars go through the speaker grill. Sounds like it won't be too bad to line up.
Old 11-15-2007, 09:57 PM
Pulling the head liner is easy, personally I'd take it out just to be safe you don't f it up, just take your time and there is a few photos on wolferacecraft.com web site of that cage with bars through the speaker grill so take some time and study them and you'll be good.
I steal ideas off sites all the time them try to do some thing different or better, I'll have the fastest looking stock motor car on LS1tech.com before the year is out =)
Old 11-15-2007, 10:26 PM
JRracing's Avatar
I got them in position, tacked them, then leaned the bar forward(T-top car) then welded the top bars, then lean it back in position. I went to the wheel wells also so the rear deck was clear or the bars. But for NHRA, they have to be to the frame rails to pass inspection. But my tracks did not sweet it!
I'll put pics up in a sec.
Old 11-15-2007, 10:31 PM
JRracing's Avatar
Here's quit a few to give you a good idea of whats involved.
Old 11-15-2007, 10:49 PM
LS1TECH Sponsor
CutlassRacer's Avatar
Nice installation!
Old 11-15-2007, 10:56 PM
car_fixer's Avatar
you said cm cage did you tig it?
Old 11-16-2007, 12:45 AM
Hennytime's Avatar
how did you make those slits in the seat for the harness?
Old 11-16-2007, 09:40 AM
code4's Avatar
The bars will be tig welded. I think I will mig the floor plates as they are mild steel.
Old 11-16-2007, 09:49 AM
code4's Avatar
Thanks for the pics, very nice install.
Old 11-16-2007, 05:37 PM
Taubr Unit's Avatar
how much was it off? Iv heard stories about how the bars are way off and you need to trim a lot off. And did you get it all notched by them or do it yourself?
Old 11-16-2007, 11:10 PM
car_fixer's Avatar
mig is fine on the plates, but tig the bars and tig the bars to the plates (yeah i know the hardest part)
Old 11-16-2007, 11:49 PM
I wish I had a tig and an extra shell laying around with a whole lot of various size c-moly tubing
Old 11-16-2007, 11:53 PM
car_fixer's Avatar
lol, i got a set of cro-mo monkey bars in mine lol
Old 11-17-2007, 01:02 AM
JRracing's Avatar
The plate, I migged in and I had a friend come over with a portable tig and weld the bars up and to the plates. I put a few mig tack welds here and there to hold it were I wanted it.
The fitment of the WOLF bars were dead on. But the rear bars needed a little trimming to get the angle tight were it met the plates to the wheel wells. And I would buy one jig notched for that reason.
The seat, I had a local interior guy cut them and stitch in a sleeve for the belts. The crotch strap comes right up through the center also. It fits real tight. Cost me $150 to have it done.
Old 11-17-2007, 01:04 AM
JRracing's Avatar
I think the plates are made of mild steel! So you can mig those.
I also recommend painting it with POR15 rust paint. It's awesome.
Old 11-18-2007, 05:03 PM
Do Work Son!'s Avatar
How much was the 6 point with the removable door bars?
