Drag Racing Tech
BTB 10 bolt v 12 bolt
Old 11-22-2007, 01:04 AM
Die Grinder's Avatar
Default BTB 10 bolt v 12 bolt
Does anybody know what kind of H.P. a 12 bolt costs v a 10 bolt w/the same gear ratios?
Old 11-22-2007, 01:07 AM
1_bad_TA's Avatar
Are you asking the cost of a 12 bolt compared to a 10? OR are you asking about strength?
Old 11-22-2007, 06:48 AM
9sec93's Avatar
i believe he is asking about horsepower consumption. which i dont know. whatever you lose in horsepower though is well worth the piece of mind knowing that its not gonna break.
Old 11-22-2007, 10:34 AM
Dave J's Avatar
going by the time and the wording of the post I would say
but yes it is well worth the money to get one and well worth the rwhp loss
I picked up mine for like 1500 used with a 373 and 410 gear sets
Old 11-22-2007, 01:22 PM
1_bad_TA's Avatar
Whats the fastest times people have ran with a 10 bolt?
Old 11-22-2007, 01:28 PM
chrismorales75's Avatar
f-body 10 bolts suck, chevy engineers should have been shot for making a car with over 300 hp that weighs 3000+ pounds with a pos 7.5/7.625 ring gear.
If the cars would have come with the 8.5 10 bolt now people could have made that live for a while.
Old 11-22-2007, 01:35 PM
1_bad_TA's Avatar
I plan to make mine live for a long time or I would atleast like it to.
Old 11-22-2007, 01:43 PM
Well you have an auto so it is much easier on the gear set than trying to drop the clutch at 6000 rpm.
Old 11-22-2007, 09:37 PM
I should have been clearer. What I was wondering, if anyone had installed a 12 bolt with the same ratio as the 10 bolt that came out and noticed a drop in mph.
Old 11-22-2007, 09:42 PM
1_bad_TA's Avatar
If there was any, it would probably be a slight change. Nothing drastic.
Old 11-22-2007, 10:09 PM
Razor_Blade's Avatar
There was a post a while back where someone lost .3 going to the dana 60 with the same ratio. I haven't saw a direct comparison for a 12 bolt. I think most people end up changing ratios when they make the swap.
Old 11-22-2007, 10:10 PM
SScam68's Avatar
no...not in my own personal experience. My traps stayed the same.
...the best part was reving to 6000rpm and popping the clutch, I had a BIG ******* grin because I didn't have to worry about the pretzel of a differential.
