Drag Racing Tech
I would like pics of madmans lt1 motor plates
Old 11-23-2007, 08:37 AM
jakesz28's Avatar
Default I would like pics of madmans lt1 motor plates
I would like pics of madmans lt1 motor plates. I will be putting a new motor in the car in a month or so and would like to see some pics of the motor plates. I think I'm going to order a PA k-member without motor mounts.
Thanks Mike
Old 11-23-2007, 09:32 AM
csjta2's Avatar
Not sure if this will help or not
Old 11-23-2007, 02:36 PM
chrismorales75's Avatar
Did it come cut like that or did you cut more off of it? Kind of looks like the bolt holes are close to the edge of the motor plate.
Old 11-23-2007, 04:12 PM
Rogue86's Avatar
I dont have any pictures, but my madman sbc motor plates fit very snugly right up against each frame rail. Fit like a glove.
Old 11-23-2007, 04:22 PM
stroked30th's Avatar
I had to take a bit off of mine to get it in there; very little though.
Old 11-23-2007, 05:11 PM
jakesz28's Avatar
Thanks and are you guys running the mid plate too? If so how did it fit in there? Did you mount it on the top or the sides?
Old 11-23-2007, 05:17 PM
No mid plate for me. Poly trans mount and a limiter.
Old 11-23-2007, 05:20 PM
csjta2's Avatar
Same here
Old 11-23-2007, 05:50 PM
jakesz28's Avatar
Did you use the factory motor mounts then too? Or are you guys only using the front plates and poly trans mount?
Not to sound stupid but what is the limiter?
Old 11-23-2007, 06:32 PM
A limiter is a rod that attaches the frame to the block so it limits the forward/rearward motion of the engine.
Old 11-23-2007, 06:34 PM
T Pizzle's Avatar
I just picked up a Madman LS1 Plate kit and Mid Plate. The mid Plate comes with the tabs to weld to the frame. I am mounting mine on the sides. When I finish up the 25.5 cage I might add a support to the top of it
Old 11-23-2007, 06:47 PM
jakesz28's Avatar
Does someone have the picture of where the limiter mounts?
Thanks
Old 11-23-2007, 07:21 PM
jakesz28's Avatar
Whats the adapters in between the heads and headers?
I like the way you trimmed below the windshield.
Old 11-23-2007, 08:01 PM
The cowl looks much better now, just got painted.
Those were a spare set of heads I had around for mockup, the headers are 1 7/8 Stahl pattern. Had to use the adapters with those heads. My RR AFR's have the holes pre drilled so no need for the adapter.
I don't have my limiters done yet.
Old 11-23-2007, 08:11 PM
jakesz28's Avatar
What brand are the headers? I need a set of those for my heads.
Old 11-24-2007, 03:10 PM
Headman Hussler. Part no. 65385
Quick Reply: I would like pics of madmans lt1 motor plates
