Drag Racing Tech
what studs and lug nuts are being used ??
Old 11-24-2007, 10:17 PM
WS6 Canada's Avatar
Default what studs and lug nuts are being used ??
What studs and lug nuts are being used on 15 X 10 Weld Prostars???
Please give part numbers if possible...
Looking into the ARP or the Moser studs and either closed or open ended lugs but do not know what type of lugs???
thanks
Old 11-24-2007, 10:25 PM
chrismorales75's Avatar
1.310'' Mag Shank - open end
ARP # 070-100-7713 .509'' Knurl Wheel Studs Late GM (F-body, Corvette) 12mm x 1.5 3.250" long
Those are for stock axles.
Old 11-24-2007, 11:53 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
If you are going with 1/2" studs it'll be the ARP #100-7703 studs and part#63004 McGard lug nuts.
http://cgi.ebay.com/ebaymotors/ARP-1...spagenameZWDVW
Good luck!!
Old 11-25-2007, 09:46 AM
WS6 Canada's Avatar
If it does matter these are for a Moser 9" rear
Old 11-25-2007, 11:37 AM
If it is for a moser rear end I would get 5/8" studs if you're going to drag race it.
Old 11-25-2007, 12:34 PM
silverbeast's Avatar
what he said.
Old 11-25-2007, 01:54 PM
NJSPDER's Avatar
www.mettec.com Titanium studs
Old 11-25-2007, 03:53 PM
TXCAMSS's Avatar
If you are going from the stock size and stepping up to a larger stud, you will also have to have them drilled out to fit the larger knurled studs.
Quick Reply: what studs and lug nuts are being used ??
