Drag Racing Tech
Kooks 1 7/8" & Nick Williams 90mm TB vs. Kooks 1 7/8" X 2" & 105mm TB
Old 12-10-2007, 09:31 AM
9 Second Club NA
Dragaholic's Avatar
Default Kooks 1 7/8" & Nick Williams 90mm TB vs. Kooks 1 7/8" X 2" & 105mm TB
I would like to swap from my current Kooks 1 7/8" x 3" and Nick Williams 90mm throttle body to 1 7/8" x 2" x 3" and 105mm throttle body. Do you think it will be worth any power on my setup?
Does anyone know the wiring needed to make the 105mm Accufab work in a LS1 being that it was designed for a Ford?
Also, is there any other manufacturer that makes a 105mm (or bigger than 90mm) that is a direct swap?
Thanks.
Old 12-10-2007, 02:41 PM
RAGENZ28's Avatar
If you're going all motor and have a 400" or more why not just run a 2" header? We run a 2" on our 406 and it makes 780 hp.
Old 12-10-2007, 02:54 PM
SSilverSSurfer's Avatar
yeah kooks has that new 2" header out now
Old 12-10-2007, 03:07 PM
ls1408cp's Avatar
i have a set of 1 7/8 2inch step headers forsale
free plug
Old 12-10-2007, 04:45 PM
9 Second Club NA
Dragaholic's Avatar
It's a 416 ci motor. I didn't know they made a 2" header. I looked every where and the biggest I saw was the stepped one I mentioned.
Old 12-10-2007, 11:34 PM
https://ls1tech.com/forums/showthrea...hlight=2+kooks
Old 12-11-2007, 12:52 AM
WMSuperSport's Avatar
I heard from a very reliable source that stepping to 2" is not worth it, unless a power adder is involved. So I got a good deal on 1 7/8" and maybe kept a little ground clearance with the 3" collector since I'm still trying to keep my car on the street.
If you call Accufab and talk to one of the smart guys, he will go through a math formula with you to figure out what size TB you need without going overkill. I thought my application was semi-serious and 90mm is more than plenty at 7200+RPM. If you decide to run a Ford style TB(Accufab, etc.) then you just swap some of the three wires and I believe it mounts on the other side of the TB. You also have to block the IAC, I think, and run a custom linkage which you have to do anyway with your intake.
No one makes a GM TB bigger than 90mm, but NW is workin on something...
Old 12-11-2007, 07:15 AM
9 Second Club NA
Dragaholic's Avatar
From what I've read in that thread, it doesn't look like I have enough cubes naturally aspirated to support straight 2" headers.
Old 12-11-2007, 08:26 AM
TNTaddict's Avatar
what about 427ci,13 comp,solid (8000 RPM shift point)?
i'm no expert but i think 2" still too much for that ^N/A combo also...correct me if i'm wrong.
keep it going,,,cuz i'm in the same situation...
Old 12-11-2007, 08:34 AM
SMKN TA 95's Avatar
Sent you a PM.
Old 12-13-2007, 07:26 AM
9 Second Club NA
Dragaholic's Avatar
Does anyone know what needs to be done to make the Ford 105mm throttle body work with our cars? I'm not worried about the throttle cable bracket, just the wiring. Thanks.
Old 12-14-2007, 05:06 PM
9 Second Club NA
Dragaholic's Avatar
So I just had an informative conversation with one of the guys at Accufab. I wanted to see what you guys thought.
He gave me this formula (ci x rpm x 3456) = maximum (100% VE)
A stock motor he claims will have roughly 75% of that. Strip/steet motor will have about 85% and a full race motor will have 90%. So in my case, I would be at 90%.
So 90% of 903, which is the VE calculated above, would be 812. He also stated that their 90mm throttle body supports over 1300 cfm. On a fuel injected motor he said that you can get away with more, but on a carb motor you need to be close to what the motor will produce.
With all that said, he said that a 90mm would be plenty and that I would be wasting my time and money with a 105mm.
What do you think about that?
Old 12-15-2007, 12:08 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
NW was working on something. That was a long time ago unless he's still at it. He was making a 100mm tb, but deamed it to not be cost effective.
To get the 105mm tb to work you need an IAC adaptor. It's either going to be a push in or thread in type. Accufab sells both models for $75.99. You'll also need to use a ford TPS sensor and adapt the harness. From what I've heard the harness is just three wires.
Old 12-15-2007, 02:11 AM
rons 00z's Avatar
hey if you're interested i have a intake elbow and a accufab 105mm TB. i saw somewhere on here how to wire it up so that info is somewhere on the board i just cant remember what keyword i used to search. i actually have a intake and rails too if you want the whole enchilada.
oh heres a post where someone said they found what wires are what.
https://ls1tech.com/forums/showthrea...hlight=accufab
Old 12-15-2007, 05:58 PM
Mark Tomas's Avatar
the kooks 1.875"x2" stepped headers have a 3.5" collector...I might be willing to buy your 1.875" kooks if you do upgrade...
Old 12-15-2007, 11:22 PM
OWN3D BY MY PROF!
I saw that a while ago also.
Old 12-16-2007, 12:10 AM
WHAT THE **** DO YOU THINK I'VE BEEN TRYING TO TELL YOU?!!
I quit...
Old 12-16-2007, 12:15 AM
Mark Tomas's Avatar
I quit...
what a tool....put the pipe down bro...
Old 12-17-2007, 06:33 AM
9 Second Club NA
Dragaholic's Avatar
Beaflag VonRathburg, I came across a couple of threads where he talked about doing a 100mm. I sent him a PM, but he hasn't read it yet. He doesn't get on too often. Thanks for the info.
rons 00z, thanks for the offer, but I'm going to stick with my 90mm throttle body and sheet metal intake.
Mark Tomas, I was going to send you a PM regarding the headers, but you don't have the option to receive them.
WMSuperSport, alright buddy, I don't know what your problem is, but I was merely saying that I took your advice and called Accufab. I then stated the info that was given to me. So I don't know where you get off saying that I'm still unsure. I just wanted to post some useful info for others, so take a chill pill dude.
Old 12-30-2007, 10:54 AM
ramairws6's Avatar
Mark Thomas..........PM me if your still looking for some headers.Traver
