Drag Racing Tech
View Poll Results: Do You Run Tubes In Your Tube Required Slicks?
Yes
26
28.57%
No
65
71.43%
Voters: 91. You may not vote on this poll
Do You Run Tubes In Your Slicks?
Old 12-17-2007, 09:12 AM
Restricted User
Zero4488's Avatar
Default Do You Run Tubes In Your Slicks?
Like the title says...I wanna know how many of you run tubes in tube required tires. Just thought I'd ask cause I've had mixed feed back....
Old 12-17-2007, 10:25 AM
RAGENZ28's Avatar
It's a personal preference I know people who have gone faster with them and faster without them.
Old 12-17-2007, 12:13 PM
Photochop's Avatar
I ran them on my old '79 camaro with 28x11.5x15 et streets just because I heard they were more stable at the big end than running without. Also heard they were more stable period with tubes. Never tried them without. BUT I had been looking into the hoosier dot QTP tires and was thinking about running them without tubes...but I may go with the drag radials instead to avoid growing on the big end.
Old 12-17-2007, 12:46 PM
Bitemark46's Avatar
None here and I have rim screws. -Mark
Old 12-17-2007, 01:55 PM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
In my experience if it's heavy or if it is stick shifted you are better off running tubes or another option would be a stiff sidewall slick.
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 12-17-2007, 04:53 PM
sickss228's Avatar
I run stiff sidewall slicks and tubes. From my experiance having this setup, the car reacts alot faster and "hits" alot harder off the line. The only downside that I have found was that the tubes added more rotational weight.
Old 12-17-2007, 05:06 PM
SScam68's Avatar
I'm running no tubes on stiff walled slick, stick car
Old 12-17-2007, 05:22 PM
kp
kp's Avatar
I use tubes in 10.5x28 stiffs and in my 11.5x28 QTPs. I have run with and without them, main reason I use them is there is never any leaks, have to use screws with tubes naturally.
Old 12-17-2007, 05:53 PM
Hrod382's Avatar
I don't currently but they will next year, basically all because of the fact that my tires are flat after sitting a week... Granted I couldn't tell you how old they are
Old 12-17-2007, 11:57 PM
Restricted User
Zero4488's Avatar
So it's completely possible to run M/T ET Drags w/o tubes???
Old 12-18-2007, 11:53 AM
Bitemark46's Avatar
Yep. All the time. -Mark
Old 12-21-2007, 06:21 PM
jakesz28's Avatar
Ran mine without tubes. Not for sure what I'm going to do next year but I hate adding air every week.
Old 12-21-2007, 10:04 PM
SSPerformance's Avatar
pain in the *** when the car sits for a week or so to fill them up everytime easyer to run tubes
Old 12-24-2007, 01:48 AM
NJSPDER's Avatar
i have used hoosier full slicks, hoosier QTP's, and i know many people who run hoosier radial slicks. no tubes in any of them
Old 12-26-2007, 05:28 AM
mike c.'s Avatar
In the past I ran no tubes in my slicks. I found my tires went flat every few days or so. I switched to tubes,my tires never went flat again and my 60 foots got better.
Old 12-26-2007, 08:21 AM
Retired Street Racer
Matt D's Avatar
I have never ran tubes. I run the 26x8.5x15 MT ET Drags. Time are in the sig.
Old 12-26-2007, 09:54 AM
stressfulcar's Avatar
I run tubes in mine,29.5x10.5 et drags. No leaks.
Old 12-28-2007, 01:57 PM
b00sted's Avatar
No tubes here.
Old 12-28-2007, 07:51 PM
XX11SECZXX's Avatar
ran my last to sets of et streets without tubes. never leaked air and never had problems. i think they recommend tubes if you want to run low pressures. never had tubes dont no what the difference would be.
Old 03-22-2008, 01:22 AM
xpndbl3's Avatar
i just smear liquid dish soap all over on the inside of the slicks two times then mount them and rarely do I add air to them, in fact the car has sat on jackstands all winter and only lost 2 psi. Do the sidewalls and the tread surface on the inside, 2 slicks uses almost a full bottle of dish soap but stops the leaks once mounted and aired up.
Quick Reply: Do You Run Tubes In Your Slicks?
