WTF is my problem?
WTF is my problem?
I ran my car today and with 2.16 sixty foot time, i ran 13.16 with a 100 shot of nitrous . If anyone can tell me why i am runing slow, i would appreciate it if u could tell me what the problem is. THANKS!
Re: WTF is my problem?
well not enough info here, but first what was your MPH stock? ET = traction and your 60' wasnt very good. also, you were spinning which means less track to actually run which means slow mph and et. get some traction, make sure your shift points were on mark, and practice practice practice. nitrous doesnt make for ET, traction does.
Brandon, what rpm are you spraying at and until? Do you have a window switch? What pills if you have 1?
Driving a stick is not that easy with nitrous-things start happening real fast .
You might just need to learn to adjust your driving and practice-practice-practice.
What do you run for time and mph on the motor?
List your entire time slip for better help.
Dave
Dave
I spray at 3000 rpm and until 6000 rpm. I dont have a window switch.
r/t .390
60' 2.169
330 5.831
1/8 8.7
mph 86.55
1000 11.113
1/4 13.166
mph 110.47
r/t .390
60' 2.169
330 5.831
1/8 8.7
mph 86.55
1000 11.113
1/4 13.166
mph 110.47
What do you run without nitrous.
Those numbers look fine for a M6 without spray. Just curious,but are you sure the nitrous kit IS working? Not trying to be a dick,but are you sure it works?
I have seen many stock LS1 sticks run that mph and time.
I have an automatic and run 8.1 @ 87 in the 1/8th.(all motor)
Did you double check the FPSS is working (if there is 1)?
Dave
Dave
INHO, it looks like since the nitrous doesnt come on till 3000 rpms (now i am fully guessing, but listen up and see if i am off base) you launched on radials nice and smooth, got a decent 60' then probably around the 80-90 foot mark, went WOT, the nitrous kicked in, and you spun all the way down the track = crappy ET and crappy mph since you were running on like 2/3s of a track at wot.
but hey, this is all a guess, but i have seen it tons and tons of times. also, i bet a rev limitor a two occured = loss of mph and ET. OR you short shifted = loss of ET or mph. finally, since this is a 100 dry shot, it will make around 80 rwhp and noticed about a 7.8-8 mph difference which is right on where it should be with that power. finally, how do you know you spray between 3-6K rpms without a window switch?
When i start i ride the clutch at 4000 rpm and then it bogs down a little. After the launch i hit the button which is around 3000 rpm. Also i shift at 6000 rpm. But when i run i am not spinning the tires threw first gear. I think i need gears personally.
Dont feel so bad. My car's best E.T. Stock was 14.0. I also went low 13's on 100 shot and 12.70's with a 150 shot. I thought I had a lemon. But, I practiced and practiced and it just kept getting faster. My car also responded REAL WELL to Bolt ons.
Slicks, Tuning, Cutouts, Headers, Gears, Lid, 3000 stall, 12 Bolt= 12.70
MTI Head/Cam/TP4400= 11.60@116 and 11.0 on Nitro.
With just bolt ons you should be in the mid 12's. First thing I would do is get some slicks.
BTW: My times stock on spray, I was spraying out of the hole.
I am totally with Doc and Gator. Bottle pressure and practice are key to a successful M6 pass. When I had my M6 it was so hit and miss on my passes. At one time (car still pretty stock) I was running a 125 dry shot on street radials and was hitting 115 mph, and only running 12.99's. It was maddening!!
I also learned that bottle pressure was as important as what kind of tires you run. If my bottle is nice and toasty (1050-1100 psi) it is night and day compared to 750-800 psi. At those lower pressures, you might as well not even run the nitrous....you just go pig rich, and the car runs like crap.
the bottle pressure that i was runnin was between 950 psi and 1000 psi
