New setup-Forged 347, PRC 5.3s,take a look
This is my new setup. Old setup using a 226/232 made 443rwhp and 397rwtq.
Old setup, stock shortblock, PRC 5.3 stage 2.5s,Cometic .045 gaskets, 226/232 .609/.604 113+2, ARH 1 3/4 longtubes, 3" Y(no cats), 4" over-the-axle into Magnaflow 4" inlet/dual 3" outlet muffler, Ported FAST 92/NW 92 TB, Fast toys lid, K&N filter, smooth bellows, 85mm MAF, Powerbond UD pulley, SVO 30 injectors, LS7 lifters, stock 10 bolt, stock aluminum ds.
New setup: (same as old with these changes) 347 Shortblock(stock crank, manley forged rods, wiseco forged pistons), PRC 5.3 stage 2.5s milled to 58cc chambers,Cometic .040 gaskets 235/240 .620/.609 112+4, Caddy race lifters, Midwest Fabbed 9" with 4.10 gears, Strange Chromoly ds, removed a.i.r. system.
New numbers are 468RWHP and 434 RWTQ!
Aside from the higher numbers and awesome torque, the car runs much better and is actually easier to drive with this setup. Ill see if I can get my tuner to post the graph, torque curve was impressive.
Nitrous will be added soon, Nitro daves plate and stand alone spraying a 200 shot.
Its similar, same duration, same XER exhaust lobe and same exhaust lift, but they use a special "Texas Speed" intake lobe where my cam has an LSL lobe with a little bit less lift. They also use a 111 lsa where as mine uses a 112+4 for a 108 intake.Puts my redline a bit lower but the torque is amazing and the car is simple to drive with gobs of power and I personally like a rough idle, and this one is perfect for my taste.
Ryne@CMS suggested the cam and it turned out awesome, also stayed at his shop with me until just after 1am thursday night finishing the tune.
Ill have some motor times on monday but wont have time to set up the n20 before then, then ill be adding a 6pt roll bar and installing the n20 and ill post time when I get em.Thanks alot!
LS1Tech Premium Sponsor
Great job! Enjoy the new combo!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
