numbers on prc 215 and tv3
Old 08-28-2009, 01:52 AM
transamfreak01's Avatar
Default numbers on prc 215 and tv3
looking into getting this set up and was wondering what numbers you put down A4s only please and also if you could put ets and how it drives, thanks a lot
Old 08-29-2009, 05:47 PM
No1? Come on guys a little help please. I've found one thread bye tsp but I wanna see others. Thanks
Old 08-29-2009, 06:31 PM
WSsick's Avatar
youre asking for a very specific combo here. you probably wont get alot, if any, responses. these heads are relatively new, so theyre wont be a ton of combos out there.
texas speed does have the new engine dyno so they could test out the combo for you and you can go off of that.
Old 08-29-2009, 07:14 PM
lilicedout24's Avatar
i had etp215 heads and ms4 cam 430 gears th350 stock bottom end ls1 11.4 my best on motor 10.3 best on a tnt 150. ask around to see those heads flow numbers against other 215's
Old 08-29-2009, 08:53 PM
yeah i know its a little specific but i was unaware that these are new heads... should 215 heads of different kinds will put out similiar numbers?
Old 08-30-2009, 03:12 AM
2001ws6-500hp's Avatar
i got prc 215s and the tv3+ boltons. u will see 11s easily if u got a convertor
Old 08-30-2009, 08:55 AM
Chris05ssTruck's Avatar
I sure as hell hope a H&C car would go 11's w/ a converter....
Old 08-31-2009, 01:11 AM
yeah it should i went 12.1 with cam only. but im looking for mid to low 11s. i have a yank ss3600 also
Old 08-31-2009, 05:47 PM
U should be in the 11's easy w/ a cam...especially w/ auto.
Old 08-31-2009, 06:33 PM
yes i no it will go 11s but i would like to see peoples results
Old 08-31-2009, 09:23 PM
TXZ28LS1's Avatar
id like to see more on the PRC 215. seems like not too many people have those heads as they are brand new. i hope TSP can post some recent dyno with those heads.
Old 09-01-2009, 06:20 PM
yeah they did one and it made 470 or 480rwhp and im guessing it was with a 90/90 and m6 but still crazy power
Old 09-02-2009, 04:50 PM
ryan@rpm's Avatar
We did one(PRC 215's & TQ3) and the customer ran it at the track this summer (HOT) and it still went 11.7's @125 ... This was in a C5Z06 .. it should pick up alot in the cooler weather ! This car made right at 480 rwhp sae and still has 3.42's in the rear. I hope this helps alittle..
Old 09-02-2009, 10:58 PM
massls1guy's Avatar
did you see this thread:
https://ls1tech.com/forums/generatio...o-numbers.html
Old 09-03-2009, 07:38 AM
ryan@rpm's Avatar
Check this thread out as well !
https://ls1tech.com/forums/dynamomet...t-90-90-a.html
Old 09-04-2009, 12:17 AM
Originally Posted by massls1guy
yeah i actually was just reading that one... havent been on in a few days but yeah he made good power with the set up
Originally Posted by jkbadz28
i didnt find this one when i searched. the car is real strong but its an m6 so itll make more.
yeah i think im set on this set up. anything anyone else recommends buying with this set up? already have pulley ls6 oil pump and double roller timing chain
Old 09-07-2009, 10:33 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We've had great results with the new PRC 215 heads. I'll keep you guys posted as we add more & more results in the upcoming weeks.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 09-08-2009, 01:08 AM
ok cool thanks a lot
Quick Reply: numbers on prc 215 and tv3
