TFS 225, TFS Stage 3 CAM Dyno Results inside
Old 10-13-2009, 06:43 PM
LSRacing's Avatar
Default TFS 225, TFS Stage 3 CAM Dyno Results inside
Finally got my tune finished up tonight. Mods are:
6 Liter iron block
TFS 225 Heads
TFS Stage 3 Cam
Fast 92mm intake
Underdrive Pulley
1.7 Harland Sharp roller rockers
2.5" exhaust Y pipe thru Magnaflow
Stainless works Long tubes
90mm DBW throttle body stock
No AC
LS7 clutch
stock 6 speed
410 gears
17/18 corvette rims
Car made 464hp and 450tq. Im very happy with it as it is. It drives perfect and the power feels great.
BIG THANKS TO TRICKFLOW FOR THE GREAT HEADS AND CAM. This car only made 400hp and 400tq on the previous heads and cam. Going to the track soon. Will post times then.
Attached Thumbnails TFS 225, TFS Stage 3 CAM Dyno Results inside-jamy-dyno-tune.jpg
Old 10-13-2009, 08:25 PM
fatmat80's Avatar
congrats on completion but numbers seem a little low to me..just my opinion
Old 10-13-2009, 09:02 PM
adam1803's Avatar
I'd have to agree with that, what are the specs on that cam?
Old 10-13-2009, 09:34 PM
venom ws7's Avatar
The numbers are not low but not the greatest either your exhaust setup is killing you.
Is SW Headers 1.3/4??
4.10 are taking some power too also LS7 Clutch is heavy.
CONGRATS.
Old 10-13-2009, 11:25 PM
Pwebbz28's Avatar
Low numbers?!?!
You do realize this cam is TINY right?
228/230 .585 112
Old 10-13-2009, 11:37 PM
LEO
LEO's Avatar
Those are good numbers, ought to run well.
Old 10-14-2009, 09:38 AM
LSRacing's Avatar
Venom, I completly agree with u on the exhaust killing the power. It is a temp soloution to get the car on the road. I'm going to a 3" with X-pipe and duals this spring and then going to retune with that. This motor is in a third gen TA and drive by wire so the exhaust was low on the list of things. Thanks for al the replys. I chose the cam for its excellent street manners and good torque curve. I love this setup. Trickflow did there homework on this heads/cam upgrade
Old 10-14-2009, 09:59 AM
RJB01camaross's Avatar
Great numbers with 18inch wheels to boot.
Old 10-14-2009, 10:54 AM
allngn_c5's Avatar
Exhaust is killing you but other then that looks cool man. I'd really like to know the specs on that cam. Are you at liberty to post them?
Old 10-14-2009, 10:57 AM
allngn_c5's Avatar
Originally Posted by Pwebbz28
Low numbers?!?!
228/230 .585 112
Is this correct ^
Old 10-14-2009, 12:09 PM
LSRacing's Avatar
Yes. Those are correct. Thanks for the reply
Old 10-14-2009, 01:00 PM
allngn_c5's Avatar
Hey bro, if you want bigger numbers you are going to need a little more cam. Something in the mid to upper 230's with lifts that match those heads. How about 234/238 .623/.623 113+3 ?
Old 10-14-2009, 01:07 PM
LSRacing's Avatar
I'm pretty content for now but maybe next year ill go bigger on the cam and see what happens. I'm thinking I could get around 490hp with a cam that size but lose some of the great street manners it has.I'm looking forward to seeing the trap speed. I'm looking to acheive 120mph or so as my goal
Old 10-14-2009, 01:22 PM
allngn_c5's Avatar
With the right tuner you won't have to sacrifice any street manners. My 402 is mild enough (until you nail the gas) to let your Grandmother drive it.
Old 10-14-2009, 06:37 PM
LSRacing's Avatar
Ill install the new 3" exhaust and X pipe and see what it does. If it gets to 485hp or so then I will leave it as is. Im not excited about changing another cam at this point. This car is alot of fun to drive now! The TFS 225's were the best upgrade Ive done to this car hands down!
Old 10-14-2009, 07:13 PM
SilverBullet73's Avatar
I wouldn't sweat dyno numbers on this combo. I have a friend that was running this combo on a Trailblazer SS 2wd. Last year in some nice cold weather at Atco, he ran some 11.70's with it on a 3600 stalled auto. If he ran that et with over 4500 lbs, then you should really pull some good times with your lighter weight. Dyno numbers aren't everything, he dynoed around 450 at the wheels. Just a thought
Old 10-15-2009, 01:52 PM
MASS seller approved
smok'nZ's Avatar
very nice numbers
Old 10-17-2009, 04:03 PM
LSRacing's Avatar
Thanks. This has been a fun car this year. It pulls pretty hard!
Old 10-17-2009, 04:31 PM
registered user
ScreaminRedZ's Avatar
Awesome numbers, I bet that car idles and drives great! I don't think 120 mph will be a problem at all unless your track is at high elevation.
Old 10-17-2009, 04:34 PM
mike c.'s Avatar
Nice,but I did the same hp you did on a 346ci w/afr 205 heads. However,you did kill me on tq. My ls1 made 463.9hp 414.5tq. My 3,600lbs t.a ran 11.1@123-124mph w/m6 trans. nice numbers and the car should haul ***. congrats.
Quick Reply: TFS 225, TFS Stage 3 CAM Dyno Results inside
