My TSP 408 Ws6
My TSP 408 Ws6
Video inside!
Finally after trouble shooting here and there, I was able to find the little problems causing it to misfire and snap at higher rpm. 3 MSD wires were arching pretty bad on my ABS lines, so I replaced the set an new NGK TR55's and she runs way better. Are these normal numbers? Im looking into getting a better tune. It was running about 11.2-11.8 at WOT. They said I could get more out of her with a better tune, but it looked like a decent safe tune. LOL. The limiter is at 6200rpm. I have been looking up ms4 cam power peaks and it seems to be around 6400? Should I get a better tune? Thanks guys.
TSP Built 408
#243 Heads w/CNC Ported
LS7 Lifters
TSP Pushrods
MS4 Cam 111.5 lsa
MSD coilpacks
Fast fuel rails
42lbs green tops
Pacesetter Longtubes
Borla True duals
Fast 90 Mani
90mm TB/ SLP maf
stock box . and dirty k@n filter lol
built t-56
4.10 gears
dana tru trac rear
1000hp chromoly driveshaft
Was tuned on efi live before, and supposivly put 550rwhp without the msd coilpack and green top injectors, fuel pump. Are these numbers right?
510rwhp
471trq
88 degrees outside, humid day. crappy 92 octane lol.
TSP Built 408
LS7 Lifters
TSP Pushrods
MS4 Cam 111.5 lsa
MSD coilpacks
Fast fuel rails
42lbs green tops
Borla True duals
Fast 90 Mani
90mm TB/ SLP maf
built t-56
4.10 gears
dana tru trac rear
510rwhp
471trq
Sounds about right. My car peaked at 6600, but I have a ported FAST92, MS3(114LSA) and PRC 2.5 5.3 heads and FAST 36# injectors completely maxed out with the stock fuel pump. You'll make a little more when the motor finally is fully broken in also. Good #'s bro, you'll be in the same boat as me needing heads lol. Your peak rpm does seem a little low. Horsepower/Torque crossover for me was around 5500ish. We have extremely close setups.
I'd be very pleased with those numbers considering your setup. If you had some 1 7/8 headers, a lid, and a retune to get that AFR up closer to 12.9:1, you'd probably be right at that 550 number. Even that is outstanding for an MS4 cam.
LS1Tech Premium Sponsor
Not bad, you're well on your way and the MS4 isn't considered a "huge" cam by most for a 408, so you should be able to get some decent street manners out of her with a good tune! Keep it up!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Thanks guys!...
No, it a Dana 60 Tru Trac Rear end w/4.10 gear. DNS 1k Horsepower chromoly driveshaft
T-56 Borg Warner built w/Dual Strip Clutch
So the ms4 isnt really a great cam for the 408?
Thanks matt@tsp! I love the motor ..super strong...im just trying to iron out all the kinks. i just recently 10 min ago lol..took the msd coilpacks off, injectors and rails , and pcm.
Sending the pcm to steve at tunedbyfrost.com
Selling the msd coilpacks, goin with stock ls1 or ac delcos, not sure yet
Pressure testing and cleaning the rails and injectors.
Thanks again guys for all the help and knowledge! All is appreciated! aloha guys!
^^^ Really? What heads and cam would you guys go with? Should I change the headers? Im getting steve for tunedbyfrost.com to give me a mail order, im shipping it prolly tomarrow overnight. And getting dual qtp electric cutouts. I just sold my msd coilpacks and putting stock 40k mile ls1 coilpacks on and new fuel filter, plugs, and wires. Any info would be great guys. Aloha!
I do not know much about cams, but the MS4 is a mild cam for a 408.
Look into something that had better mid power, as far as i know the MS4 is mostly topend power, you cam pull higher than 6400. Have someone spec out a custom cam with some better LSA and it might sound better. I had the MS4 in my 346 and i hated the idle.
Awesome numbers!
Awesome numbers!
