LS7 Heads/Cam Dyno final results: 619whp/532wtq !!!!
Ahhhhhh.......finally done.. I started a thread a couple of weeks ago about my preliminary results of 587whp/508wtq. We couldn't get an accurate tq reading on the last dyno, and the 508wtq was measured at 4200rpms. I got a few things sorted out with the car. Vaccum leak, and changed the plugs out from TR55's gapped at .050" to TR6"s gapped at .035". The compression is 12:1.
The car is an absolute animal. I almost lost it on the way home from the dyno on the 2-3 shift. The car makes between 607whp-621whp SAE depending on what smoothing/rpm/mph scale you are using, yet the tq is 532-533wtq. STD numbers are between 620whp-631whp and 543-544wtq. The car is very sensitive to timing due to the compression so we left it very conservative. The car's power does not fall off. I love this forum for sharing everyone's build so I can try different things and stick with the stuff that works. I couldn't be more pleased.
I can't thank the Jeremy's enough on this build. Jeremy Formato for helping me plan literally every stage and take so many phone calls I lost count. Also Jeremy Preston from Horsepower Sales in Pompano beach for putting together my monster and working with me on how particular I can be about what's happening with the car etc. Otherwise, after careful selection this is a build that can be duplicated by anyone with standard parts ordered from vendors here on our forum. It's all in the combination!!!
Just to recap the build:
2008 Z06
dyno'd today in davie, ambient temp 87* humidity 58%
Mods:
LG 1 7/8" long tubes no cats
Halltech KB II
Nick Williams 102 tb
FAST 102 ported by Jeremy Formato of FASTERPROMS
FAST billet fuel rails
Stock mufflers modded by Jeremy Formato
Tuned by Jeremy Formato
Comp Cams short travel hyd lifters
Comp Cams trunion upgrade w/stock rocker arms
Comp Cams Valve seals
Comp Cams pushrods
AI Heads(Stock ls7 castings CNC ported by Advanced Induction)
Stock valves
Comp cams off the shelf 235/251 .657/661 ground on a 114+4
Electric water pump
ATI 10% underdrive pulley
Stock clutch
Stock brakes
Stock wheels with stock size tires(non runflats)
2008 Z06
Mods:
Halltech KB II
Comp Cams pushrods
Stock valves
Electric water pump
Stock clutch
Stock brakes
Congrats Doug! That's one of the highest dyno numbers I've seen on a n/a Z06. It must be awesome to drive. So will you be taking it to the track? I'd love to see what that car will trap.
