PRC As Cast Heads Dyno Results on 01 Z06
Old 03-26-2012, 02:09 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Default PRC As Cast Heads Dyno Results on 01 Z06
We just finished dyno testing a production version of the PRC As Cast Cathedral LS cylinder heads & I'm completely pumped up about the results!
The test car is a 01 z06 cam only car with the following mods:
Z06 LS6
243 Heads
Tsunami Camshaft
PRC Spring Kit
TSP Headers & X Pipe
Stock Mufflers
Vararam intake
The only addition was a set of PRC As Cast Cathedral Heads. The car gained right at 30hp & 24lb ft of torque! That's a awesome gain over a LS6 head, keep in mind that'd probably be 45-50 over a stock LS1 241 casting!
The first production run of these heads are expected to be ready less than a month so keep your eyes open for new results very soon!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 03-26-2012, 02:11 PM
__________________
Jason
2005 Twin Turbo C6
Old 03-26-2012, 02:50 PM
2QUIK4U's Avatar
Nice results!
Old 03-26-2012, 03:33 PM
Rise of the Phoenix's Avatar
Been following your thread in the Internal Engine section. Can't wait for these to come out. Any idea on pricing yet?
Old 03-26-2012, 09:04 PM
mac62989's Avatar
Nice numbers!
Old 03-26-2012, 09:24 PM
94dragbird's Avatar
You should get some track results too
Old 03-26-2012, 09:52 PM
Moderator
LIL SS's Avatar
How do they compare flow wise to the 237's?
How big is the valve?
Old 03-26-2012, 10:17 PM
NemeSS's Avatar
Good results.
In for specs and pricing
Old 03-26-2012, 11:09 PM
taman86's Avatar
Same as above...
Old 03-26-2012, 11:36 PM
01ssreda4's Avatar
Any plans on CNC'd versions?
Old 03-27-2012, 01:01 AM
camaro-coz's Avatar
Dear TSP , you gotta go for a small bore LS3/LS7 heads for the LS1/LS6's "3.905" bore. I would be the first one who buys them! with a small bore cnc'd LS3's, I think they will flow up to 350-370cfm which with pull up 60-80rwhp over the LS1 heads.
so a H/C ls1 with cnc ls3 heads could reach 500rwhp easily
Old 03-27-2012, 12:29 PM
taman86's Avatar
Look at mast's small bore version heads. They don't flow that much at all. The small bore version flow something like 270 cfm or something, I know its below 300
Old 03-27-2012, 04:04 PM
camaro-coz's Avatar
I've heard of them by a friend ...
and as you know , the Mast's are pretty expensive (not worth it) , even more expensive than the TFS's .... while the TFS's , PRC's , AFR's have a much higher flow ....
Old 03-27-2012, 04:14 PM
427LS7HCI's Avatar
How did you figure 60-80rwhp over LS1 heads???
TFS 215s would outperform small bore LS3/LS7 heads on a 346ci.
Old 03-27-2012, 04:15 PM
427LS7HCI's Avatar
Z06 LS6
243 Heads
Tsunami Camshaft
PRC Spring Kit
Stock Mufflers
Vararam intake
Any Flow numbers?
Are these stock casting or aftermarket castings?
Old 03-27-2012, 04:40 PM
taman86's Avatar
Ummmmm....just going out on a limb here but I have to guess aftermarket being that they are cathedral port and out perform the ls6 style heads by 30 hp.
Old 03-27-2012, 04:50 PM
They are most certainly aftermarket castings. Check out the thread in the Internal Engine section. Can't remember if Texas Speed posted flow numbers in that thread or not.
Old 03-27-2012, 06:56 PM
venom ws7's Avatar
Another great product from TSP.
Great work I'm sure I'll be buying a set very soon to test
Old 03-28-2012, 04:18 PM
Nobody has built a ls3 port on a small bore because they cathedral heads we offer now will dominate a LS3 intake port setup IMHO.
This is a complete aftermarket casting head with the ports cast similar to our cnc versions.
__________________
Jason
2005 Twin Turbo C6
Old 03-28-2012, 05:07 PM
JS01's Avatar
FWIW:
http://www.mastmotorsports.com/2010/...sembled&id=360
Quick Reply: PRC As Cast Heads Dyno Results on 01 Z06
