LQ4 EPS Cam Dyno Results/Questions
Finally got my cutlass dyno'd. Not sure what to think of the results. Not 100% happy. My tuner couldn't be there but I do have hp tuners i'm just not that good with it. I was able to add timing. Didn't mess with the fuel mixtures. I was getting 12.8-13.2 A/F I know its a little lean.
Setup
LQ4 block w/ Katech Rod Bolts
CAM
Intake Duration: 234 Degrees at .050" Tappet Lift.
Intake Lift: .602" with 1.7 rockers.
Exhaust Duration 246 Degrees at .050" Tappet Lift
Exhaust Lift .607" with 1.7 rockers.
111 Degree LSA
243's milled .006 for cleanup
LS9 Head Gaskets
LS6 Intake
P&P LS1 TB
G-Body Swap Headers
Full 3" exhaust
Built TH350 w/ 3.73's
Graph is attached. Max was 361whp. I'll get the TQ #'s tomorrow. IIRC they were 375-380.
What my main question is is why is it losing 100hp on the top end?
http://i311.photobucket.com/albums/k...611_143217.jpg
Setup
CAM
111 Degree LSA
LS9 Head Gaskets
LS6 Intake
P&P LS1 TB
G-Body Swap Headers
Full 3" exhaust
No RPM pickup? How high did you rev it? I don't think the numbers are that bad, considering the tune could be better and the inefficient drivetrain. What makes you think it's losing 100 hp?
Not really a loss but most dyno graphs go up at the end until it stops making power, so its like after 6k i'm not making any more power and i'm not sure why i guess is my question.
Sorry was running it out to 7k
I should get the graphs tomorrow, didn't have a flash drive to get them off so just have my picture.
Link to Video, hopefully it works
http://www.facebook.com/photo.php?v=...e=2&permPage=1
How are the swap headers as far as flow? I made 417/390 through a 6 speed in my mustang with that cam. Mods are in my sig, stock untouched 241s, ls6 intake, untouched TB, kooks long tubes, UDP.
Im guessing the auto and stall is killing it. How does it feel on the road?
1- That converter is not gonna give dyno queen #'s for sure, BUT it ought to run good at the track is what I'd be worried about anyways
2- If that's a stock bottom end LQ4, you only have around 9.5:1 compression. My friend just popped his LS1 and bought a LQ4 and put his heads and cam in it, the car lost 63 RWHP with the 6.0 cause of the loss of compression.
On the street it feels like a monster, we raced an R6 the other night in it only had a bike length on me from a 40 roll when we shut down @ 120 ish. Not sure on his riding skill i don't think it was the greatest but from a roll was pretty impressed. That was before the dyno and gaining the extra 15hp.
I'm guessing its the stall and auto as well thats what a lot of people have been telling me. It slams that converter on the hit on the street and pulls really good. Also have the trans brake.
Its a stock bottom end LQ4 but it does have the 243's that are milled .006. I think IIRC its like 10.2:1 from reading other posts.
I mean if i'm getting a 20% loss through the TH350 and converter. 20% of of 361 is 72. Which comes out to 433. So through a 6spd it would probably be about where I thought.
itsslow do you have a dyno graph I can look at to see how your curve looked at.
I'm just still not understanding why after 6k it falls so hard. What does everyone think about the 12.8-13.2 A/F should I add some fuel? I know I need to tweak my curve a little I like the 12.8 better than the 13.2.
IMO you should take it to a professional tuner. That way you won't be on the edge with A/F ratios and they can also probably tell you where - if anywhere - you're losing power.
Your numbers seem to be within normal for the compression and converter and everything, especially if the tune isn't spot on.
Not sure what you mean by losing 100hp...that is not a 460rwhp set up in any situation. Even in a manual trans car on an average dyno I would be shocked to see over 420rwhp.
My tuner is a professional tuner. He just couldn't be there for the dyno. I live in Lima and the school UNOH is there and I have friends that go there and they got me on the dyno.
By losing 100hp i mean after we hit peak power by 7k i'm down over 100hp from the peak. I just expected it to keep pulling and not fall off over 100hp.
That is the exact same cam I have in my LQ9, and it didn't dyno much more, but the kind of 1/4 mile ET's these Cams produce leads one to think they are making much more power.
KC you went 12.0 weighing like 4400lbs? I weighed the cutlass in at 3480 with me in it. I suspect it'll run 11's. How deep I don't know.
Mike we dyno'd it Monday around 2pm. I have the car out at orielys on the weekends. I won't be out for a couple weekend though.
11's will be no problem for a light car like yours.
