EPS Cam only 222/226 115+3 results!!!!
My daily driver 2002 WS6: 104k miles on the clock, 6 speed with a lid ,GMMG catback and suspension stuff being the only mods going into this.
I decided to hold off on getting heads because it was just not in the budget, regardless of installing new lifters.
Ok so many of you remembered the car had issues on the baseline dyno. It was falling flat at 3800 RPM with a max reading of around 250 rwhp on all 3 pulls. Something was off and Bill had suspected a collapsing lifter causing valve issues.
Well Billy and crew at ForceFed performance tore into it on Tuesday and buttoned up everything late last night. It produced pretty good results considering how small this cam is without any supporting mods outside of a lid and catback.
Final numbers were 364.9 rwhp and 345.7 torque.
With headers and a retune I think it would be close to 390 rwhp which isn't bad at all for such a small cam.
Overall I wish...wait for it...wait for it.... I would've went with a little bit bigger cam, LOL!. It probably would be tough to pass smog with any bigger of a cam. This one has a little bit of lope but it would've been nice to have more lope for enjoyment purposes alone.
I can't figure out how to post a PDF file to show you guys the dyno chart
I told myself I would be happy anywhere between 360-370 rwhp/torque going into this. So yeah I'm happy. Decent power and it'll pass smog easily out here in Commiefornia.
Thanks again to Geoff over at EPS for all of his advice and time in helping me select the right cam to create good power on stock manifolds.
******UPDATE 6/28/12: DYNO CHART SHOWING CAM ONLY BEFORE HEADERS THEN AFTER HEADERS********
http://www.youtube.com/watch?v=vurTq...layer_embedded
http://www.youtube.com/watch?v=xi5BZ...eature=related
LS1 Tech Administrator
Nice comeback. Good results. That cam is really nice. If you decide to upgrade to 243 heads at a later date, it will work really well with them.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
We didn't really find out for sure. But when he had tuned it the power readings were smooth throughout without dropping off like it had been doing.
A nice flat torque curve too. I suspected it may have been a collapsing lifter messing with a valve but the stock ones looked fine when we pulled them. I replaced the lifters, and every seal and gasket from here to the moon as well as all the standard parts(LS6 oil pump/timing chain/ etc) to replace to do a cam swap the right way.
Gracias!
From a lopey idle standpoint and not a performance standpoint a little more lope would have been nice to listen to.
Yup! passed smog about 3 months ago the legit way.
I know for many folks having a daily driver cam that passes smog and makes good power is a plus.
I then added BBK Lt's and a catted y pipe.
With headers and the retune it made 390/365. A nice set of heads and i would hope for 420 rwhp.
The best i have done at the track so far is 12.8@111 with a below avg 60 ft for the 555r's.
Lol, regardless they do a helluva job.
A dyno is just a tool right? Track numbers are real world numbers.
