Comp LSR Cam
Old 08-13-2012, 01:32 PM
the_merv's Avatar
LS1Tech 10 Year
Default Comp LSR Cam
I stumbled upon an article...
http://www.gmhightechperformance.com...t/viewall.html
Where the Comp LSR Cam, 251/267, .624/.624, 115LSA was used.
Has anyone worked with this Cam? How did it perform? What are some good valve springs to support this?
Thanks.
Old 08-13-2012, 03:13 PM
Brian Tooley Racing's Avatar
I used it in my N/A 454 that made 705 hp.
My Platinum springs work great if using stock rocker arms.
Old 08-17-2012, 11:26 AM
litle88's Avatar
Comp suggested using their 925/926 springs with that cam. I have one of those LsR and use the 926's.
Old 08-20-2012, 08:32 AM
ramairws6's Avatar
Thanks.
I have the first cam in that article. Seems to be a good performer. Hmmm, i wonder if i shouldn't have opted for this one instead by the looks of it!??
Old 08-20-2012, 09:55 AM
The 926 springs have too much open pressure if using stock rocker arms and will damage valve tips long term if used in a daily driver application.
The 925's are a better choice if using stock rocker arms. If you look at my Platinum springs and the 925's I think you'll see some stark similarities.
Old 08-23-2012, 02:03 PM
the_merv's Avatar
LS1Tech 10 Year
How agressive are the lobes on this cam? I think I found the one that is the next size lower. Car isnt a daily driver..has stock rockers tho.
247/263, .624/.624, 114 LSA, Comp LSR Cam # 54-473-11
Old 08-23-2012, 08:14 PM
turbociv910's Avatar
has this cam in a stock bottom end c6z with heads/fast intake manifold and nick williams 102 tb and made 588rwhp
Old 08-23-2012, 08:38 PM
My6speedZ's Avatar
They use LSL if I'm not mistaken LSR is a series of cams not a lobe.. They are supposed to be easier on springs than XER lobes and more stable while being soft on/off the seat and was designed to be stable while still offering decent lift but not being as aggressive as the LSK lobes. Some people say they are great, while some people say they make similar power to XFI lobes. I don't really know, I don't work in a shop; and I don't see a ton of different combo's. Someone with more valvetrain expertise will be able to tell you more.
Old 08-23-2012, 10:51 PM
the_merv's Avatar
LS1Tech 10 Year
I currently have PAC .650 Springs.. Pretty much on the fence with them springs and the cam that I posted.
That's good **** right there..
Old 08-23-2012, 11:26 PM
My6speedZ's Avatar
Originally Posted by sweets10v8
i run 918s on my lsr cam, but only because my valvetrain is very well setup and tested. The 26926 is the new dual spring designed to work with the lsr line of cams.
Originally Posted by patrick g
exactly. If you are running heavy solid stemmed valves, it's best to run a quality dual valve spring with lsl lobes. If you have lightweight valves and rockers, a good beehive like a comp 26918 or pac 1518 will control the lsl lobes.
Most people will need to run duals.
fwiw.
Old 08-23-2012, 11:44 PM
the_merv's Avatar
LS1Tech 10 Year
I'm not exactly sure what PAC ones I have..
Old 08-24-2012, 12:23 AM
Do you have the PAC springs made for TEA like failed on your heads before? I would replace those as soon as possible. My Platinum springs are $129 shipped and have never failed. They are a drop in installation with your existing components.
Old 08-24-2012, 11:30 AM
the_merv's Avatar
LS1Tech 10 Year
Yup I have the same ones. The current cam in the car is pretty mild so ofcourse no issues.
What springs are you referring to?
I've been looking at the 926's..
Old 08-24-2012, 12:07 PM
My Platinum springs are the most durable springs that I've found in my 15 years of building LS cylinder heads. As you may know I'm the former owner of Total Engine Airflow so I have some experience under my belt. You can check them out here. http://www.briantooleyracing.com/660...l-springs.html
Whatever you do, don't run more than 400 lbs of open pressure if using stock rocker arms. Too much open pressure can damage the valve tips long term.
Old 08-24-2012, 12:22 PM
ramairws6's Avatar
I thought the PAC 1521's were an excellent spring? What happened to that now??
Old 08-24-2012, 12:26 PM
the_merv's Avatar
LS1Tech 10 Year
Ah good stuff sir..I may be giving you a call..
Old 08-29-2012, 08:48 PM
litle88's Avatar
Sorry I meant I'm using the 925's. The car is not a DD but it is only a weekend car. What should I look out for? As far as valve tips are concerned? Do you have any pics of damaged valve tips? Do you have any tips?
Thanks
Zeke
Old 08-30-2012, 09:00 AM
Thanks
Zeke
I do have a couple of pics of stock LS2 heads run with a LSr cam and 26926 springs, although the quality isn't the greatest. These were from a otherwise stock C6 LS2 using Comp cam, lifters, pushrods, trunnion kit and 26926 spring kit.
The valve tips should be flat and smooth, just like stock. With too much open pressure they will start to pit, look uneven, and eventually will stop rotating and have trenches cut into them.
The things that will help prevent these issues is running .630" lift or less with stock 15 degree rockers, running 400 lbs or less open pressure, running stock locks which allow valve rotation, and any type of oil additive that helps flat tappet cams prevent wear. Such as racing oils with zinc, etc.
Obviously running roller rockers will prevent this wear, but the heavier roller rockers need increased spring pressure and increased pushrod rigidity.
Old 08-31-2012, 12:03 AM
litle88's Avatar
Ok I use valvoline vr1 20-50 non synthetic, I have the trunion upgrade and my cam has .624 lift in it. But I do have 405lbs of seat pressure open. Suggestions, recommendations?
Old 08-31-2012, 09:06 AM
You're running good oil with the zinc additives, and I think with 405 lbs open pressure you'll be OK. Just pull a couple of rockers off every winter and make sure the valve tips look OK.
Quick Reply: Comp LSR Cam
