Dyno results: LS1 RX-7 with A.I. HC 241 heads
Figured I would post this for Phil at Advanced Induction and for some more hard data pertaining to these specific heads
My car is a 1988 RX-7 with a 2004 GTO LS1. 2 years ago I completed the swap and made 425 rwhp and 417 rwtrq. Supporting mods were:
Engine:
2004 LS1(LS6 intake, and block) 32,574 miles,
TSP 228R 114LSA,
Katech rod bolts,
PAC 1518 springs,
TSP 7.400 hardened push rods,
241 cast heads,
Custom 4" intake and 4" SLP MAF with resistor removed,
ported/polished TB
1 3/4'' Longtubes
2.5" dual exhaust w/ flo-monster X- pipe.
Magnaflow 14616 mufflers
Tuned by Frost & by Brian R.
Drivetrain:
2002 F-body T-56
RAM lightweight aluminum flywheel
LS7 clutch
Factory Mazda Diff LSD, 4.10 ratio
Old Dyno Sheet:
OLD dyno vid:
[/SIZE]
-------------------HEAD SWAP-------------------
So this July I wanted to get some more power because I was bored and wanted to tinker. Heard of AI's results and wanted to keep this head swap$cheap$.
I ended up ordering Phil's 219cc High Compression "241" head option. I wanted factory deck height and retained a 60cc chamber size. This made my compression ratio 11:1.
I used the GM MLS head gasket.
I also had to upgrade to Ford 30lb injectors which were input in HP tuners as 34.5 lbs/hr @ my 57 psi rail pressure.
NO other changes were made
The results were: 476.6 RWHP & 430.4 RWTRQ
DYNO VID:
Dyno Sheet (in the works to get a revised copy emailed to me with matching HP and TRQ scales for better comparison reasons)
I am very pleased with the results! Phil and his shop does some amazing things with the 241 heads
Few pics of the RX:
Engine:
TSP 228R 114LSA,
Katech rod bolts,
PAC 1518 springs,
241 cast heads,
ported/polished TB
1 3/4'' Longtubes
Drivetrain:
2002 F-body T-56
LS7 clutch
Old Dyno Sheet:
OLD dyno vid:
DYNO VID:
Few pics of the RX:
What kinda dyno is that? Excellent gain from the heads but both baseline and after heads numbers it seems like a very optimistic one. 430whp 417tq cam only with a very mild 228R is WAY above normal results.
Thanks for the compliments on the car.
It is a DynoCom 21,000 series. DynoComs are known to be very "torque happy". These are all corrected numbers too guys.
Remember, the dyno is just a tool for comparison reasons just like this very case with upgraded parts. I was fortunate enough to have access to the exact dyno used 2 years ago.
Once I get this thing down the 1/4 mile, we will see its true power.
So let's assume it's a happy dyno, which it seems to be. Still, 50hp gain from head porting alone is crazy! Assuming a stock headed 228 cam engine might make 390 rwhp on a more conservative dyno--this setup would be about 440 rwhp on a mild cam and no FAST--pretty good IMO.
Very nice results and GREAT job on that engine bay!!! CLEAN!.. And I agree the dyno is just a tool, your 1/4 mile results will be what I'll be looking forward to but I would expect to see some big MPH gains 4-6 is my best guess.
I am also surprised that your peak power on the first graph is un der 6K and after is right at 6K, Looking back at some of my old graphs my 224cam ls6 heads peaked right at 6,200
Regardless whether the dyno reads high, it still shows a significant gain with the AI ported 241 heads. Where are all these "internet expects" at now that say you can't make good power with 241 heads. It's all about who does the port work and AI is one of the best. Beautiful car OP.
THANKS every one for the kind words on the car. It has been a fun swap and the car is a damn rocket in street trim.
I will post my 1/4 mile time hopefully on Sunday. I am hitting the strip up here in Lewistown on the 28th. Elevation is 4200 feet but regardless I will see what she can do. My 60' foot will suffer because of my fragile diff but hopefully i can keep it below 1.9 lol
I watched a bone stock 2003 Mustang GT put down 255rwhp, and a CAI/Flowmaster catback/Lightning pulley/tune 03 Cobra put down 480rwhp on a Dynocom many years ago. IMO they're worthless.
AI's CNC work on the intake/exhaust ports and chambers are the VERY reason these heads made power.
As for what you have seen with the mustangs on a dynocom really isn't too hard to believe.
The 4.6L V8 from Ford has been dyno'ed mutiple times in stock trim and averages 245-255 rwhp.
An 03 Cobra with a tune, higher boost and breathing better is going to make substantially more power, hell look at what a good tune alone makes for power on a stock LS1/LS6. Now 480rwhp may be a bit high, especially if on a dynocom because everyone knows they are generous but that rwhp doesnt seem way out of line.
Yes dynocoms are a dyno-queen's favorite but if used consistently with the same car over the course of time with modifications, it is nothing more then a tool.
Yep..... you must be right..... my engine just miraculously made 50 extra HP from the slightly WARMER air temp & LESS humidity last week compared to the 2 years before on the exact same dyno. Come on man!
You CAN make good power with 241 castings, but it won't be done with CNC, regardless of who programs it.
Marc,a 50hp gain on an already cammed engine, with just a head swap,is definately possible. a CNC port comes from a hand ported one that has been digitized so the original port is replicated,for the most part.of course there's usually hand finishing involved,so i don't see your arguement.
do you port heads for a living?
