LS1 with AI 226 CNC heads/Fast 92mm dyno results
Old 03-12-2016, 07:33 AM
camarof41_383's Avatar
Default LS1 with AI 226 CNC heads/Fast 92mm dyno results
I put a stock LS1 from a 2002 Z28 in my 91 Camaro about 2 years ago. It was stock other than tune, Stainless Works 1 3/4 LT headers, 3.5in Mufflex exhaust, and FTI 3200 stall torque converter. That combination made 340HP, 350ft.lbs. It ran a 12.8@109.7 on cheap Firehawk tires with that combination.
I made some changes over the winter, wanted some more power without spending a huge amount. Since this car is mainly a weekend cruiser that makes a few drag strip passes a year I wanted to stay fairly conservative. I want to run a decent 1/4 mile but didn't feel the extra expense of AFR/TFS heads would be worth it for what I'm doing with the car. I picked up a set of 243 heads from a Z06 corvette with the light weight valves...happend to find them locally for a good deal last fall. I contacted AI and Phil recommended a cam/heads package to get me where I want to be, I'm very happy with the results.
Here is a full run down of the combination.
Stock 2002 LS1 short block, around 36k miles
243 heads, AI 226 CNC porting, milled to 62cc
BTR .660 valve springs
Comp Cams Trunion upgrade
AI 228/232@.05, .625 lift, 112LSA cam
Fast 92mm intake
1 3/4 LT headers
3.5in Mufflex Exhaust
Nick Williams 92mm throttle body
Fast 36lb injectors
85mm MAF
stock 4l60e
Strange 12 bolt with 3.42 gears
For those wondering about the drivablilty of the combination, it drives very well. The idle is slightly rough but not too bad. I can still turn the AC on at idle, rpm dips a little but it doesn't want to die. It lost a small amount of low end torque but at about 3500 rpms it really comes alive. I wouldn't want to go any bigger with the cam in my application. It's a pretty good balance of power and driveablilty.
The attached graph shows the stock combination vs. the new H/C/I combination. Same dyno jet dyno for both. I realize dyno numbers don't mean a whole lot but this is a good comparison since both combinations were put on the same dyno. I think it would benefit from steeper gears and a higher stall speed torque converter but since it's mainly a street car, I'm not planning on changing anything unless something breaks. I'll find out how it does at the track later this year.
Attached Thumbnails LS1 with AI 226 CNC heads/Fast 92mm dyno results-ai6.jpg   LS1 with AI 226 CNC heads/Fast 92mm dyno results-ai2.jpg   LS1 with AI 226 CNC heads/Fast 92mm dyno results-ai3.jpg   LS1 with AI 226 CNC heads/Fast 92mm dyno results-ai4.jpg   LS1 with AI 226 CNC heads/Fast 92mm dyno results-ai5.jpg
LS1 with AI 226 CNC heads/Fast 92mm dyno results-ai.jpg   LS1 with AI 226 CNC heads/Fast 92mm dyno results-ai7.jpg   LS1 with AI 226 CNC heads/Fast 92mm dyno results-ai10.jpg   LS1 with AI 226 CNC heads/Fast 92mm dyno results-ai11.jpg
Old 03-12-2016, 07:38 AM
madmike9396's Avatar
Bet that's a whole new animal
Old 03-12-2016, 10:41 AM
Toes's Avatar
That is a huge increase! I bet you'll see mid 11s on the track. As long as you can get it to hook. Also that is a clean an in great shape 91!
Old 03-12-2016, 10:50 AM
Toes's Avatar
Old 03-12-2016, 10:54 AM
Rise of the Phoenix's Avatar
Nice. What made you go with the 226cc program over the 232cc program?
Old 03-12-2016, 11:30 AM
blk00ss's Avatar
What muffler is on the mufflex?
Old 03-12-2016, 12:05 PM
jmilz28's Avatar
Was the converter locked for the dyno runs? Really nice numbers for a 12 bolt stalled auto regardless. You'll see 11s with a decent tire easily.
Old 03-12-2016, 05:46 PM
Camaro99SS's Avatar
Great results through that auto and 12 bolt for sure. I'd be happy with that considering you left some compression on the table and have a FAST 92 instead of a 102.
Jason
Old 03-12-2016, 06:23 PM
I don't think I would have gained much on the top end and would probably loose a little more down low with the larger runners. If I was building a larger displacement engine I would have gone for the 232cc program for sure.
Old 03-12-2016, 06:24 PM
Magnaflow Muffler
Old 03-12-2016, 06:25 PM
Converter was not locked. I think it will run pretty well, definately has 11 sec potential if I can get any traction.
Old 03-12-2016, 06:30 PM
Jason
I agree, I'm happy with the results. Its not totally optimized but runs well for what it is.
Old 03-12-2016, 07:18 PM
blk00ss's Avatar
Originally Posted by camarof41_383
Magnaflow Muffler
Ok good. Just making sure it wasn't the **** spin tech. I bet with a cutout there's another 7hp or so there.
Old 03-12-2016, 09:43 PM
LilJayV10's Avatar
Those are great numbers through a stalled auto and 12 bolt.
I bet that thing is a blast do to drive.
Old 03-13-2016, 12:44 PM
Definately a blast to drive. Need some better tires though, not much traction with the firehawks.
Old 03-13-2016, 02:17 PM
Post some pics of your car. Looks nice from the above pics
Old 03-13-2016, 03:06 PM
high n dry's Avatar
Whats wrong with spin tech mufflers???
I never had an issue with them.
Old 03-13-2016, 04:43 PM
LilJayV10's Avatar
IIRC, some people have found they flow poorly. It's been a while but there was a guy that went from a Spintech to a Magnaflow straight through muffler and picked up quite a bit of power.
Old 03-13-2016, 05:23 PM
Here are a few more pics.
Attached Thumbnails LS1 with AI 226 CNC heads/Fast 92mm dyno results-img_0126.jpg   LS1 with AI 226 CNC heads/Fast 92mm dyno results-exhaust1.jpg   LS1 with AI 226 CNC heads/Fast 92mm dyno results-12227008_10205293051598225_8316443723437795896_n.jpg   LS1 with AI 226 CNC heads/Fast 92mm dyno results-10311767_10205193421545308_5538699275077394611_n.jpg   LS1 with AI 226 CNC heads/Fast 92mm dyno results-fastls1.jpg
LS1 with AI 226 CNC heads/Fast 92mm dyno results-strange1.jpg   LS1 with AI 226 CNC heads/Fast 92mm dyno results-img_0153.jpg
Old 03-13-2016, 05:44 PM
Damn that car is so freaking nice!
Quick Reply: LS1 with AI 226 CNC heads/Fast 92mm dyno results
