My 1999 Z28 Dyno & Track Results
Before the PI Vigilante 4000 10.5" Multi Disc and 3.73s the Car Ran a Best of 12.73 @ 111 with a 1.98 60ft with the Stock Converter and 3.23s. After the PI Vigilante 4000 10.5" Multi Disc and 3.73s the Car Ran a Best of 12.23 @ 110 with a 1.68 60ft. IMO It's 1 of 2 Things Short Shifting or Converter Slip, When the Car Trapped 111 Shift Points were Set at 6500, When the Car Trapped 110 Shift Points were Set at 6400, The Car Made Peak Power at 6290 and Starts to Fall Off Drastically After. Should I Raise the Shift Points with Power Falling Off? Should I Command the Converter to Lock Up at WOT?
https://ls1tech.com/forums/generatio...o-talking.html
My old SS was the same way.. heads and cam trapping at 113 scraping 11.99 barely with 1.6 60 ft.. car would feel awesome out of the hole but wouldn't pull hard the rest of the way... never figured mine out but I suspected a bad tune, poor compression in a cylinder, or maybe an intake leak or something.. a few weeks after the track I blew a hole in my piston.. no nitrous or anything.. yours may be different but I suspect something is off or the tracks timers are off lol
#33
Here's an Update Guys, The Stock 853s are Off. The Lingenfelter CNCd 799s are On, Along with GM LS7 Lifters, GM LS2 Lifter Trays, GM MLS Head Gaskets, GM Head Bolts, BTR Titanium 660s & CC 7.375" Pushrods Due to the Heads Being Milled to 62cc. Guesses On Compression, Power, ET & MPH Gains?
#37
Better but it should be running faster than that. Could be the converter, maybe the cam...it shouldn't be dropping off that fast after peak HP.
Maybe the Dorman LS6 you have is poorly built and extra restrictive?
I would do a leak down test.
Also, another member had a wonky MAF and after replacing it, he picked up a bunch. Maybe try someone else's MAF to test it out.
https://ls1tech.com/forums/11-second...-11-831-a.html
Good luck!
Good luck!
