Another AFR 205 dyno result: 490/443
Afr Dyno Results Here:
Orginally Posted on Corvetteforum.com
02 Z06
AFR 205cc
490rwhp/443rwtq
234/238 .598/.605 111lsa 109 ICL
11.2:1
Fast 90mm Intake
90mm TB
LG pro long tubes
Clarks Z06 – 467 / 431 – AFR – G5x3 – LS6 – stock throttlebody
Tony M. – 480/437 – AFR 205 – 224/228 – 90/90
TTP Z06 – 474/429 AFR 205 – v.02 cam – LS6 = stock TB
22349(b) CVC – 472/426 – AFR 205 224/228 – LS6?
Lgmotorsports AFR header testing: 471/432
A&Acorvettes – 452/411 – low compression 224/228
02 Z06
AFR 205cc
490rwhp/443rwtq
11.2:1
Fast 90mm Intake
90mm TB
LG pro long tubes
I wonder why AFR introduced a 66cc chamber in the first place ?
Edelbrock had their 63cc unit out at SEMA but was iffy on their timing. Trick Flow confirmed that they are "developing an LS head" but still only able to flash a pick. The future looks great. I commend AFR for setting an amazing bar with a great product.
The 02 Z06 that is the car this post is based on, will be on the dyno here in about 2 hrs.... Ive got about the most conservative dyno (I consider it realistic more than conservative) The most a heads/cam 346" car has made on our dyno is about 440-450 rwhp.... Several of those cars in that range are running 11.0-11.50 in full weight 3500-3800 lb street cars...
If this z06 puts down 490 on the dyno here, i will absolutely be jaw dropped and impressed. Cant wait to see it in a while. I'll post later with results..
Shorty Director
I keep seeing varying #'s on these heads. What amazes me is the #'s are not even close to each other. Tq #'s ranging from low 400's all the way up to 482rwtq. That's very odd IMO. Some claiming touched and untouched AFR heads. I wish someone would clear up the HUGE differences. It is very confusing to the consumer. If all it takes is a HUGE cam to produce crazy #'s with these heads then this also needs to be cleared up. Compression is a big factor as well, but the consumer needs to know what would work with pump gas or race gas. If there is a variable that the consumer needs to know to provide us with information to help us make a good decision when it comes to spending OUR money. No one likes to get dooped. I am also interested in AFR 225 heads in the future, but I want to know if they are worth sending to FMS/Meaux to add a lil more to them, because in my case that would be a $4k to $5k investment for just heads.
