Guess my problem using dyno =)
Well, my car has been runnin a little funny so I headed out to dyno day to see how the power band looked comparativly to how the car feels. I was thinking that my fuel pump was going out. Im running a 97 Vette fuel rail. I heard it making noise a while back but it stoped. Then after the dyno it started up again. But stoped- I baby the car and dont drive it much. But this is ugly. The car drives like the dyno shows under WOT - as well as has a ( untuned cam feeling surg) when the car is idling ( not always but often) . But tha AF was like 15 + on 2 of the passes. This sheet was on a pass where the car downshifted ( so a 2nd gear pass probly) but they all looked like this. Im gonna check the maf to see if theres K&N oil on it, but Ive got no codes thrown and this problem isnt Brand new. Any input would be great - =) Im just poor so cant just throw money at it yet.
k&n oil can do that to ur maf???... i know i followed there instructions recently to apply and clean that ****, somehow i got it on to heavy lol, and that **** seems to have gotten everywhere like it never quite tried out or what not. think im going to order a new air filter.
as far as ur problem, i have no clue dude, u would think it would be something fuel wise but then ur a/f ratio woudl be all over the place no?
the no codes thrown yet is what is really amazing.. seems any lil thing out of order and u normally get a code.
That is crazy looking I'll give you that one for sure. Have no clue on the problem, but I would try changing the fuel filter and put some good gas just to rule those 2 things out. Good Luck!
WOW ! !....part or all of your problem stems from that A/F ratio - I'm surprised the person dynoing didn't warn you from making more pulls with your car. An A/F that high can definitely do damage to your engine. The issue is probably stemming from the MAF (I've seen that before).
I would STRONGLY suggest getting a tune very soon.
.....I would also suggest going to a different shop, since it appears that this one didn't bother to take the time to explain things to you.
Take a look at this thread.....
https://ls1tech.com/forums/dynamometer-results-comparisons/266222-first-dyno-s-what-ya-think.html
I believe he had a similar issue
For the time being, you might want to put the stock MAF back on.
Sorry, I guess that I misread your post -
The oil on the MAF could cause some of the problem but unless you've put it back in wet I think that there's something more going on. I would have them also look into the fuel rails (as stated above).
Keep us posted.
Keep us posted.
