Car isn't running Good After Dyno Tun
Old 02-16-2005, 04:53 PM
Johnny vette's Avatar
Unhappy Car isn't running Good After Dyno Tun
I have The Car about a month after the tune, The Weather Is about 60. getting on Express way [3 rd gear] Hit the gas and the car is moving good and [4 th gear] the car starts to like lose some power . I call the shop Where the work was done and said to bring it in next thursday... any ideas what the problem is ? Also spark plugs were Changed .
Old 02-16-2005, 05:33 PM
I just remembered the car was pinging and the service engine soon [SES] light went on . then it went off ?
Old 02-17-2005, 08:31 PM
Anyone ?
Old 02-17-2005, 09:17 PM
TheBowtieboy's Avatar
More than likely, the pinging is causing the engine to pull timing and that's what is making the engine lose power.
"pinging" is usually a result of a lean condition - hard on the engine......take it easy until you get it re-tuned........a proper tune will fix that.
If this is a dyno tune, I would strongly suggest bringing the A/F ratio down to 12.6 - 12.9. Most will say 13 is perfect, but IMO it's starting to boarder on going a little too high. Rememer, a dyno is pretty much a free spinning roller and produces little resistance; the road creates a lot of resistance. Resistance will cause your A/F to lean out more.....thus, what you see on the dyno will be more rich than when you drive on the street.
Good luck !
Old 02-18-2005, 03:12 PM
Bad gas or low octane ? On my last fill up i don't remember what the guy put in, i usally watch...
Old 02-18-2005, 07:04 PM
LS1Tech Sponsor
Slowhawk's Avatar
Could be gas if it started doing it after filling it up.
Old 02-18-2005, 08:41 PM
You don't remember what he put in it ?
.......always run the super unleaded !
.....and yes, that can cause pinging.
Old 02-26-2005, 10:26 AM
Default It wasn't the Gas
It Was The # 2 Spark plug.... Now Im Happy Again .
Old 02-28-2005, 06:31 PM
What's Wrong With this Forum??? No pulse here... The Place That Did The work messed Up...
Old 03-02-2005, 12:46 AM
rawlitogut's Avatar
What was wrong with plug?
Old 03-02-2005, 07:55 AM
dynocar's Avatar
What's wrong with the pulse here? Without knowing what happened to the plug, we cannot assume that this place messed up? Want to see my can of plugs that failed, some right out of the box, many brands.
