We need a new Sticky in the Dyno section!
Old 05-03-2006, 11:35 AM
SlickVert's Avatar
Default We need a new Sticky in the Dyno section!
Lets have a Sticky that would be broken down by CI like 346/347, 383 ,402/408, then Bigger then 408.
Then have the car list by HP in there CI category.
Then each category should have a list of mods in order like Heads, Valve size, Compression, Cam spec, Header size, Trans, Rear end (10/12Bolt or 9 inch), Gears, ect.
Kind of like looking under Racing Department, then Drag Racing Results section at the ET Data Base, Stock Internals or Cam Only times Sticky’s.
This would be a great way for everyone to compare different Cubic Inch Motors, with what Heads and Cam combo work best.
What do you all think?
Bob
Old 05-03-2006, 11:50 AM
HAULNTA's Avatar
Cool
I like it.
Stang's Bane's Avatar
Agreed 110%
Old 05-03-2006, 12:35 PM
7 Second Club
Phil99vette's Avatar
Lets do it
Old 05-03-2006, 05:17 PM
slow trap's Avatar
sounds like a great idea to me also.
Old 05-03-2006, 05:39 PM
NEVRLIFT's Avatar
I was thinking of this idea too. I'm glad someone came out with it. It would make comparisons much easier.
Old 05-03-2006, 11:05 PM
CNB
CNB's Avatar
I'd like to see this happen.
Old 05-04-2006, 12:04 AM
SVT THIS's Avatar
Ditto-I think it'd be a lot easier for people to research what they'd like to do as well.
Old 05-04-2006, 12:15 AM
whiteLS1's Avatar
it would get rid of a lot of WHAT WILL MY COMBO MAKE threads
if it could happen it would be nice
Old 05-04-2006, 01:03 AM
'Trust''s Avatar
Great idea!
Old 05-04-2006, 07:17 AM
SlickVert's Avatar
OK!
How do we go about making it happen?
I am guessing that one of the administrators would have to set it up, we all would post our info. Then someone would have to fill in the table, with the posted info.
Let’s start listing all the type of data we would like to see.
Bob
Old 05-04-2006, 10:21 AM
ThirdGenLS1's Avatar
yea that would be a great idea, just need to figure out how to go about it.
Justin
Old 05-04-2006, 11:04 AM
MightyBobo's Avatar
Maybe simple stickied threads titled as appropriate for each displacement. Then, simply post your mods (whatever you dynoed with, at least) and what your dyno numbers are along with which type of dyno you used.
Old 05-08-2006, 03:34 PM
obZidian's Avatar
this is a great idea..
A good way is to start by a title with the repected CI grouping and catergorize it by transmissions. Than type of dyno...and of course mods or any custom work, whatever, anythign special you want to add about your combo. Weather, location or geography.
that would be sweet.
OK... everyone, we need to get this done... lets all try to post here that info and/or whatever you feel is necesary. Possible make a call for EVERYONE, plez post your dyno info here... blah, blah, blah.... you know what, its done...
Old 05-10-2006, 09:59 PM
jrp
SN95 Director
jrp's Avatar
its not that hard guys. if you want to do it then put it together and organize it and one of the mods will sticky it.
Old 05-10-2006, 10:13 PM
Brandon Boomhauer's Avatar
Yep
start it out, make it nice and easy and I'll (or any other mod) that likes it and approves will sticky it.
I'm willing to help out with any of it, heck I may throw something together before long but I'd rather have something to work with first. We need some more action in this forum and more results and postings.
Old 05-11-2006, 09:02 AM
SlickVert's Avatar
Ok let get started.
Let’s put the info in the order we would like it, then hopefully an administrators can post it as stick.
Let’s have a similar format like the Drag Racing Results sticky for Quickest Stock Internals or Fastest Cam Only Car list.
Everyone can post the data in the correct format, and then the administrators can update the master data base in order of the highest to lowest HP in each category by CI.
CI, HP/TQ, Dyno Type, Heads, Valves size, Cam, Compression, Header size, Intake, TB, Tran. Rearend and gear, ¼ mile ET/MPH
Post away!
Bob
Old 05-11-2006, 09:03 AM
SlickVert's Avatar
SlickVert, 346, 467/400, Dynojet, ET215, 2.040/1.57, T-Rex 243/249 609/613 109+2, 11.8 to 1, 1.3/4, Fast 90, 90, M6, 12bolt/4.56, 10.97@126.2
Bob
Old 05-11-2006, 09:13 AM
KGSloan's Avatar
KGSloan, 347, 423/390, Dynojet, Absolute Speed CNC'd 5.3's, 2.04/1.57, G5X-3, 11.2:1, 1.75", LS6, 78mm, M6, 12-bolt/4.11's, 11.64 @ 119
Old 05-11-2006, 10:04 AM
SlickVert's Avatar
REVISION to format
CI, HP/TQ D=Dyno M=Mustang, Heads, Valves size, Compression, Cam, Header size, Intake,/TB size, Tran. Rearend/gear, ¼ mile ET@MPH/race weight
