Bolt-on stalled A4 results
Old 06-06-2006, 09:41 AM
you2slo's Avatar
Default Bolt-on stalled A4 results
Car was dynoed last night for before/after comparisons. With 3400 2.1 STR stall and all bolt-ons minus pulley: 303HP/343TQ. Not nearly as high as I would like but I'm still happy with my track times so far. I'll post the graph after the cam is installed and tuned.
See... I'm an auto and not ashamed of low dyno #'s.
Old 06-06-2006, 10:26 AM
Justin01SS's Avatar
Looks like that about what you should put down through an A4 I would think. Did you get it tuned with all those bolt ons?
Old 06-06-2006, 11:46 AM
2002BLKWS6's Avatar
What did you put down before the stall? Just curious since I have similar mods to yours, but I have't dynoed the car since I got the exact same stall as yours put in.
Old 06-06-2006, 12:44 PM
Muerte_X's Avatar
Can you post the graph, was it locked/unlocked, SAE? Kinda strange that the tq is so high compared to the hp and I would expect your hp to be higher than that, since you have longtubes and an LS6 intake.
You said it was a before/after comparison? Before/after the stall, or longtubes? What were the before numbers?
Old 06-06-2006, 01:19 PM
Old Drag Racer
Smokinstorm's Avatar
As long as the car pulls the numbers at the track I guess it doesn't really matter that the M6 guys are quoting RWHP numbers that the A4 guys can only dream of. I pulled 328.9 after Jeff Creech worked his magic on my car. He tried a lot of things to get it there. I've got a PT4000 converter and I'm not sure if that helped me or hurt me compared to the thread starter. Just like him I'm happy with my track times even though the numbers seem really low compared to what I see posted on here all the time. A4's are definitely not Dyno Queens.
Old 06-06-2006, 01:21 PM
you2slo's Avatar
These #'s are before the cam. These are the baseline with all bolt-ons minus pulley. Car is untuned. I will post a before/after graph with all mods now plus, cam, pulley, and tune next week after vacation!
Old 06-06-2006, 01:25 PM
'Trust''s Avatar
Locked or unlocked?
Old 06-06-2006, 05:36 PM
you2slo's Avatar
#'s are SAE corrected and locked.
Old 06-06-2006, 10:18 PM
jpat1023's Avatar
umm... if I get to full bolt-ons and I post a 303rwhp I am not going to be very happy, A4 or not...
Old 06-07-2006, 11:36 AM
solocus's Avatar
I agree!
Old 06-07-2006, 11:39 AM
Detroitmuscle's Avatar
Sounds about right to me untuned. Stalls eat up tons of HP but produce much better times at the track dyno numbers don't mean ****.
Old 06-07-2006, 10:57 PM
2001 White Ws6's Avatar
I had very similiar numbers with my bolt on stalled a4. Did 310-343 with long tubes, lid, and 3400 converter. With cam was 351-354.
The stall is probably accounting for 10-20rwhp but it makes up for it in performance.
Old 06-08-2006, 01:20 AM
Muerte_X's Avatar
Was that dyno with a locked converter too? I sure as hell hope I pick up more than 10whp from longtubes and an LS6 intake.
I thought locking it pretty much elimintated the big hp loss you see from the stall?
Old 06-08-2006, 05:00 PM
Converter was unlocked. I'm curious to see what the numbers would be with the converter locked.
Also to answer your question on the difference between the hp and tq numbers is the converter flashing. If he posted the graph i'm sure you'd see a sudden jump in tq and it falling gradually through the rpms.
Old 06-08-2006, 05:22 PM
86 IROC's Avatar
My car did 318 untuned & unlocked, 323 locked. 348 after a tune - locked, SY3500 stall for all dyno runs.
Old 06-13-2006, 10:13 AM
you2slo's Avatar
Just for an update: looking at the graph, my TQ jumps right at 3400 to the peak, then it falls off slowly. The car needed tuned BAD! After 228R cam, pulley, and tune I made up some power.
Before: 304/343
After: 371/348
The torque hits 340 @2700 RPMs and holds it 6000 RPMs
Old 06-13-2006, 07:30 PM
slimcracka's Avatar
damn man..get some track times awsome #s
Old 06-13-2006, 11:38 PM
LS1iFiEd's Avatar
My car did 338RWHP and 350RWTQ Full bolt ons with a PCM4Less Mail Order tune on a stock Converter, I now have a Fuddle 3400/2.1 STR as well, my times went from 12.3 @ 114 to 12.0 @ 112 I lost 2 MPH But Dropped 3 tenths.The car has been real strong since day one 13.1 @ 107 Stock.Im happy with it I know the M6 guys cant run those times with the same Mods
Old 06-14-2006, 09:49 AM
you2slo's Avatar
Best ET: 12.47
Best MPH: 113.92
Still pulling 2.0 or worse 60' due to crappy Walmart tires.
Old 06-14-2006, 11:02 AM
Wicked_Hugger99's Avatar
id say 303rwhp is not bad and its running 12.80s@109mph which is damn good. I ran 12.40s@110mph w/ 335rw or so with skinnies and 275/50 15in BFG DRs.
