Got the ride tuned today what do ya guys think?
Old 08-16-2006, 12:58 PM
maverick18's Avatar
Default Got the ride tuned today what do ya guys think?
mods are...
-hand ported 241s stock valves
-TSP torquer 232/234 .595/.598 113LSA
-Edelbrock LTs
-LS6 intake
- Lid and ported TB
- Textrella clutch
426 RWHP
368 Torque
Old 08-16-2006, 01:00 PM
NVR KNO's Avatar
nice horsepower numbers, but shouldnt your torque be up alil higher? i mean with just headers and a lid, my torque is 360. and thats with the stock ls1 intake too.
Old 08-16-2006, 01:08 PM
bad95killer's Avatar
Awesome RWHP number & as LastLT1 mentioned it seems the Torque abit low
Could post the graph though ??
peace
Old 08-16-2006, 01:24 PM
maverick18's Avatar
yea when I had just headers and a lid torque was at 326 and hp was 334. I just moved so im going to have to dig the scaner out of a box somewhere but ill try.
Old 08-16-2006, 02:33 PM
ArcticZ28's Avatar
My bet is that it has to do with the hand porting. The ports or runners are most likely too large, causing peak gain but loss in the low and mid range flow.
Old 08-16-2006, 06:54 PM
maverick18's Avatar
http://s66.photobucket.com/albums/h271/mavricki18/ pics of the heads are under "the wip" still havent found the scaner to post the graph up
Old 08-16-2006, 06:59 PM
ArcticZ28's Avatar
The work looks pretty good, but without having the heads in person and taking measurements along with flow numbers it's hard to say whether the port work was beneficial (in terms of useable power) or not. Like I said, I'm leaning towards not as beneficial in the areas that you spend most of your time in on the street. Porting heads will almost always gain you hp/tq up top, but it's the low and mid lift numbers that make a great head. Not trying to knock your work or efforts because I can certainly appreciate someone taking time to learn how to do that stuff and actually trying it on their own. Just sharing my opinion on the numbers that came out of the porting regardless of who did them.
Old 08-16-2006, 09:00 PM
maverick18's Avatar
no offence taken I am a poor college kid and couldent afford a more trusted CNC ls6 or 5.3 head that run around $1,000 or more. So I had a buddy that use to port heads and work on a IHRA pro mod team do it for a decent deal. A couple of things I forgot to mention was that the headers I have are 1 1/3 stepped to 1 7/8s. I also had my cutout open so back pressure was at a minimum. Those to things alone point to more peek power than low and mid range torque. Also not sure if this makes any diff but it was on a Mustang Dyno.
Old 08-16-2006, 09:14 PM
WHPLASH's Avatar
Poor college kid or not, damn good numbers Dane!!!
Old 08-17-2006, 07:52 AM
NVR KNO's Avatar
well if u were on a Mustang Dyno then your numbers would raise when you put it on a DynoJet. still man, good numbers!
Old 08-17-2006, 08:07 AM
ArcticZ28's Avatar
Are you serious, or do you mean 1 3/4 stepped?
Old 08-17-2006, 08:17 AM
1slowls1's Avatar
same thing happened to my car, it still runs good though. You made a bit more power but the tq is almost the same, I was told my heads are too hogged out, and my compression is too low for my cam, result = low numbers.
Old 08-17-2006, 11:13 AM
maverick18's Avatar
yea that was a typo 1 3/4
Old 08-18-2006, 07:35 PM
maverick18's Avatar
Heres the Graph ....
Dyno graph
Old 08-18-2006, 08:11 PM
AINT SKEERED's Avatar
If those are on a Mustang dyno then they are pretty dang good. Even still the tq curve looks nice.
SMoking 01 T/A (Rodney) went 10.2's with 370 ft lbs of tq
Old 08-18-2006, 08:14 PM
red1999z28's Avatar
Dyno graph
Wow...looks like the motor wanted to keep going up till about 7k...I'd bet you pick up another 15hp spinning it that hard.
Old 08-18-2006, 08:34 PM
allngn_c5's Avatar
I don't care what the people said about low torque. I would love to have my torque curve go straight up then do a dome shape up to the peak and slowly drop off afterwards. Your HP line is great!! That sucker comes on and keeps on coming. You probably could pull a few more ponies by spinning to 7k but why risk spinning a bearing. You got a bad *** car!! I am going to pm you about something you may be interested in...........
Old 08-18-2006, 09:19 PM
allngn_c5's Avatar
I'd love to set up a run between you and cgillies86 or between you and myself. I already sent you a pm. Hope to hear from ya. The forum could always use more good vids. Chris is the man when it comes to putting them together. Hope to hear from ya. Awesome car, I am nervous about running into you.
Old 08-18-2006, 10:38 PM
Tri5Nerd's Avatar
Default What's you SCR and DCR like?
I heard that you'll need to bump the compression to make that cam perform like it's name.
Old 08-18-2006, 10:51 PM
maverick18's Avatar
I wannted to get the heads milled .300 when I had them off but I was just flat out of cash. What CR would that cam perform best at?
