Most C5 Dyno Graphs have...
Old 09-16-2006, 06:05 AM
Billiumss's Avatar
Question Most C5 Dyno Graphs have...
I have noticed that a lot of C5 dyno graphs have a weird curve to it in the beginning of the dyno run. It starts out kinda flat then really takes off. I have seen this on cars I've tuned, you can even hear a sound difference too.
Why is that?
Old 09-16-2006, 03:20 PM
lilbuddy1587's Avatar
Dont they have a driveby sensor as opposed to a throttle body cable?
Old 09-16-2006, 03:33 PM
7 Second Club
Phil99vette's Avatar
Never seen it before.
Old 09-16-2006, 08:11 PM
JoeyGC5's Avatar
Are you refering to the tip in? Whent he computer transitions from closed loop mode to PE mode?
Old 09-16-2006, 09:07 PM
LS1Tech Sponsor
Slowhawk's Avatar
I know what your talking about it flattens a bit at the beggining if you start at a low rpm.There is a fix to that.
Old 09-16-2006, 09:18 PM
oange ss's Avatar
LS1Tech 10 Year
Etc Tm ?
Old 09-16-2006, 09:33 PM
Kano's Avatar
well ...what is it?
Old 09-17-2006, 06:16 AM
Billiumss's Avatar
Exclamation
Yep that's it, seen it a lot, even in most C5 Dyno posts on this board.
What's the "fix" if you don't mind sharing.
Bill
Old 09-17-2006, 06:24 AM
hyde's Avatar
The bottle!!!!!!!!!!!!!
Old 09-17-2006, 10:26 PM
NEVRLIFT's Avatar
My uncle's Z06 had the same thing on his dyno sheet.
Old 09-18-2006, 12:00 AM
Robert56's Avatar
Like this, c5 Z06:
Robert
Old 09-18-2006, 07:49 PM
MSGHUFF's Avatar
I always thought it was because of the way the drivetrain is on a vette? So whats this "top secret" fix????
Old 09-19-2006, 01:24 PM
WS-Sick's Avatar
I think the "fix" is the bottle. Be careful though, I hear it's addictive.
Old 09-19-2006, 04:25 PM
LS1Tech Sponsor
Slowhawk's Avatar
Here's a hint This is a blown Vette with no dip at the beggining.What do you change with a Vette when you put a blower on
Sorry,took me a year to figure it out.So I'll make it a quick learning experience for you guy's but you have to guess
Old 09-19-2006, 05:50 PM
CNB
CNB's Avatar
Air/fuel. I also see you made it much richer at peak torque.
Old 09-19-2006, 06:21 PM
7 Second Club
It has to be P/E Delay, my car never does anything close to that. You can hammer the pedal @ 1k and it will go right to the target A/F.
Phil
Old 09-19-2006, 08:08 PM
Robert56's Avatar
Phil
I set my PE rpm on lower, and have no issues even off the bottle, also. This is also a good dry tuning trick.
Robert
Old 09-19-2006, 08:11 PM
LS1Tech Sponsor
Slowhawk's Avatar
No,thats just tuning being screwy on the A/F.The blue graph is a NA run,red is blower.
It's not an A/F problem.The Vette's do something different
Old 09-19-2006, 08:24 PM
98SS2836's Avatar
You change timing, And injectors. I believe that would be a must.
Old 09-19-2006, 08:31 PM
98SS2836's Avatar
Im just thinking does it have somthing to do with the DFCO?
