Should I be close to 450rwhp?
2001 Camaro SS 6 speed
PRC 5.3l stg 2.5 heads 62cc
VRX5 cam (236/238 .601/.605)
42# injectors
Full bolt ons (LT's, GMMG, UD pulley, LS6 intake)
I'm hoping this combo will hit around 450whp/400wtq, but I think I may need a fast 90 or 92 combo to get the job done...Any thoughts?
42# injectors
You have a pretty budget setup. Budget setups don't (for the most part) make premium power.
Good luck man
Yeah I would rather underestimate so I am not disappointed if don't hit a certain number. The only thing budget about it is the heads, and they are proven to make "premium" power. I'll shoot for a lower a number, just wanted to see if it was at all possible to hit 450!
Yeah, budget setup dont make premium numbers like he said, unless components are perfectly matched. I know it. I dynoed 405rwhp(on a lower reading dynojet,whatever..)when I expected at least 420-430rwhp. If I ever get on a standard dynojet, I'll redyno it, but I know now you have to get those AFR TFS ETP to get over 450rwhp..Anyway, my setup is far from beeing optimal.
Well, good luck!!
Well, good luck!!
Yeah perfect example...this guy and many other I have seen put down great #'s. Everyone gets caught up up with the premium heads thinking they put down 40 more hp to the wheels. Budget heads are good for 40whp...premium maybe 50whp...10hp difference for over a grand more in cost...
I would say you would be REAL close with a 6speed..I'm an A4 with tsp stage2.5 5.3 heads ported fast 90/90 and my cam is about the same size..It's 232/238 6xx 6xx 111+2lsa..I put down 435 rwhp 407 rwt.. I know that I have a ported fast,but I'm an A4,which dynos alot less than a 6speed,so I think you'll be real close with what you have
it was Mamo ported and then I did some additional porting/sanding to the inside top shell (I removed it to paint the intake gloss black) and the middle and bottom shells together. here is the write up that I did on it...
https://ls1tech.com/forums/showthrea...478&highlight=
here is another link as well..
https://ls1tech.com/forums/showthrea...014&highlight=
