Cam-only numbers (Pat G 226/232)
Here is my set-up
stock bottom-end
unported/unpolished 98 heads (milled .020)
stock MLS gaskets
LS6 intake
hooker LT's/ORY through a dynomax bullet
SLP lid
Old dirty K&N filter
Pat G spec'd 224/230 comp cam
tr55 plugs
MSD wires
I told Pat G that I would expect this cam to net me atleast 400rwhp, his response was "I don't want you to get your hopes up too much for a 400 rwhp dyno number. This cam is a 50 rwhp cam. To exceed 400 rwhp with 98 heads will require a substantially bigger stick with a lot less street friendly manners. Of course, your small bump in compression will help some too."
Today the car went on the dyno for tuning. the pull was aborted a bit early due to an issue with the tranny leaking fluid. They said the car made 394@5800
Car goes back on the lift Monday to fix the problem (hopefully there is nothing damaged) and I am hoping to have the car back on the dyno next week.
I believe the fuel that is in there is about 8-9 months old. Does fuel breakdown after sitting for a bit?
Update 7/8/08: Graph is now up. Final grind on the cam came out to 224/230 on 111+1 LSA
I am going to get the car back on the dyno soon
Figured out how to change it to SAE correction.
stock bottom-end
stock MLS gaskets
LS6 intake
SLP lid
tr55 plugs
MSD wires
Its not bad, Pat G knows his stuff and I am glad I talked to him just days before the t-rex went in. I pulled the TH400 out of the car so its a street car again. I dont think I am really giving up anything to the T-rex and I am sure I will have way better low/mid end torque and power.
first, chris you are REALLY REALLY going to enjoy that car. second, 394 rwhp at only 5800 rpms shows me that the motor really makes power under the curve as well as it will peak at easily 6400 rpms and make over 400 rwhp for a broad range.
great combo. lets see what she makes overall. like i have always said, those big Trex style cams are great for selling hype. for a car like yours, that combo is sweet (and cheap and reliable!).
I thought about what you have said in the past and I decided to talk to Pat. Like I said, I dont think I will be giving up much (if any0 to the t-rex up high... maybe just carrying out the rpms but i will be shifting no further then 6800rpms (have to wait until I see a graph before I decide that) I believe Jeremy said it was at 240rwhp/375 ft.lbs@3500 (I cant exactly remember), but if that is correct, this thing is making very-very nice power under curve and should very enjoyable.
Didn't do them, he said he didn't want to get into doing exhuast work at this moment so all I have is the hookers into my ory with a dynomax bullet dumped before the axle. I want to find a stock cat-back or a dual/dual to put on teh car and put a cut-out on as well. This way I can have it quiet when needed.
I was researching graphs and I am not seeing very many cam-only cars hitting the numbers I listed above at specified RPM's so I am eager to see what the car does and see a graph. From te sounds of it, I am going to be very happy.. just cant wait to have the car again.
LS1 Tech Administrator
Solid gains Chris. Right where I expected you to be! Look forward to seeing your dyno curves.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Just messing bro. I dont really care to put it on their dyno just to show you that it will or wont break a certain number. If you would like to cover the dyno fee, then I will gladly put it on there... your call.
Nice #'s...I have a 229-233 .571 .578 on 114+2 going in with my stock 98 heads that have been milled .040 with MLS Gaskets
I would love to pull anywhere from 385-400RWHP and 380+RWTQ through my locked Vig 3600. I should have Dyno #s next Saturday
But this was ground specificly for my nitrous combination on my stock shortblock so I'm not sweating the N/A dyno #'s... It should be a monster on the 150-200 RWHP hit and another 225-250RWTQ through my nitrous dedicated fuel system(C16 F T W)
What LSA and how much advance did you order it with?
With those MLS gaskets on the 98 heads did you weld the little notch in the heads to keep the MLS gaskets sealing?
