Another near 600rwhp LS7 PRC heads Cam Combo!!
Guys we just finished another PRC LS7 head/cam car that made really good power! Look for it to get a electric water pump & break the 600rwhp mark very soon!
This car had
08 Z
ported customers heads STOCK COMPRESSION!!! STOCK COMPRESSION!!
TSP S Cam
Kooks Headers & X
Ported LS7 intake & TB
TSP Tuning
I'd love to see this car with some milling on the heads, this car could have easily out dyno'd my 605/535 #'s I bet!!
Enjoy!!
This car had
08 Z
TSP S Cam
Kooks Headers & X
TSP Tuning
Enjoy!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
1 Post
Would love to see the bump in compression, and add the the EWP. Should add a nice chunk of power, and the added compression should bump up low end torque.
AWESOME Job guys !!!!!
OWN3D BY MY PROF!
If you had milled the heads how much would you have milled them? I can only seeing it being about .5 to 1 point of increase. That's at most around 12 rwhp and you'd probably have to pull some timing out. Don't get me wrong because I think this is a well thought out combo. I just think that you shouldn't put so much emphasis on the fact that it has only 11:1 scr.
LS1Tech Premium Sponsor
The little bump in compression most go with definitely helps! Here's another with 11.4:1, and the LS7R camshaft!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
from 5400 to 5800 it looks pretty close, I guess if there is no knock its ok but that is leaner than I would think would make optimum power. could also be a wide band stuffed in the muffler and a small exhaust leak, I know there was some variance between what I was seeing at the collector and when the w/b the dyno was hooked to was seeing at the muffler.
