dynoed today.....why such low numbers? VID inside
Old 08-18-2008, 11:09 PM
adam`'s Avatar
Default dynoed today.....why such low numbers? VID inside
the mustang has a 00 camaro drivetrain, champion ported heads (62cc chambers), tr224 cam, ls6 intake, ported throttle body, 28lb injectors, and 1 3/4 MAC long tubes.
24* of timing
the car has a built 4l60e with a 3400 PTC converter and the rear is a built 8.8 with 3.55s.
here is my dyno sheet and here is the vid.
http://media.putfile.com/94-Mustang-LSx-Dyno-Pull
Old 08-18-2008, 11:10 PM
Twisted636's Avatar
what where the injectors flowing at? if they where at there limit then you will not see all the power u should be making
Old 08-18-2008, 11:21 PM
adam`'s Avatar
the injectors are running at about 78%
Old 08-18-2008, 11:25 PM
stevegrizzle's Avatar
timing? any more details on the heads?
Old 08-18-2008, 11:27 PM
ballerchris510's Avatar
Because the ls1 is in a mustang just messin with ya....
Old 08-18-2008, 11:30 PM
adam`'s Avatar
i would say they are comparable to the afr205s. 24* of timing pulled...i spray the car.
Old 08-18-2008, 11:38 PM
well if you want more n/a power obviously adding in the 6 or more degrees of timing will liven thing up a bit.......
that and the converter and rear end explains it I think.....
What intake manifold you got on it?? you should be closer to 400rwhp with those mods...
Old 08-19-2008, 12:06 AM
adam`'s Avatar
ls6 intake....
Old 08-19-2008, 10:26 AM
adam`'s Avatar
bump..
Old 08-19-2008, 10:29 AM
here is your answer.........
If you have it tuned for spray and are running w/o the proper timing you will be down on power. You could throw a fast combo on there but I doubt you will pick up more than 10-15 @ the wheels.
Old 08-19-2008, 10:46 AM
JScamaro's Avatar
Small cam, automatic, low timing, built rear = low numbers.
There is no way he should be making close to 400 rwhp imo with his setup.
Old 08-19-2008, 11:23 AM
rocksws6's Avatar
I really don't think 6 degrees of timing is going to make a big difference. He might gain 5-10 hp. Not really enough to justify his low #'s.
I think something is wrong personally. There is plenty of stalled cars out there making more than 350whp. With H/C car like that it should be close to or over 400whp. The Rear is likely soaking up a few hp but not enough to justify the #. I would start to investigate myself.
Old 08-19-2008, 11:28 AM
KEE AUDIO's Avatar
I have a smaller cam then that (TR220) with a Yank SS3600 stall, tune, Dynatech LT's, GMMG cat back, and 3:73's and make 345hp and 380tq.
Old 08-19-2008, 11:37 AM
Frost's Avatar
Originally Posted by adam`
i would say they are comparable to the afr205s. ....
uhhh wouldn't that be nice.
Was the converter locked or unlocked in the pulls? Looks unlocked, and that alone will put a hurting on dyno numbers.
Good thing we don't race dynos.
Old 08-19-2008, 11:42 AM
pulling 6* of timing is only going to make a 5-10 hp difference? Dude, no offense, but have you ever dyno'd cars with that much timing pulled compared to the optimum timing? It could easily be in the 25-30 hp range depending on his setup.
I would say try to get a n/a tune if it is that important to you to make a better number. Otherwise if it pulls good on the juice and that is what it is intended for, then why bother?
Old 08-19-2008, 12:50 PM
adam`'s Avatar
converter was not locking up. im not to worried about the numbers as it makes GREAT power with the juice. it just looked real low to what it runs at the track.
11.60's @ 122 on motor....
10.80's @ 128 on a 100shot
Old 08-19-2008, 07:02 PM
your times seem about right... + thats what counts... what are you waiting for to hit it with a 150...
Old 08-19-2008, 07:41 PM
adam`'s Avatar
i was waiting for a built rear and built tranny. i have both now so i will run the car tomorrow or friday wether permitting. we have a tropical storm over us right now.
Old 08-20-2008, 06:44 AM
LS1Tech Sponsor
Slowhawk's Avatar
To me it looks like a locked converter.Timing is fine unless the heads are really un -efficient which would reguire a ton more timing. AFR/224 makes good power at 24 degree's.
Looks to me like you have an inlet or exhaust restriction.Or the heads are wrong for the setup.
