Car is being tuned on Dyno today, results to follow.
Complete mod list is in the sig. A few points to mention:
1). Stock heads (for now).
2). Fast 90 is NOT ported.
3). Dyno is a dynojet.
4). Car has a steel driveshaft that replaced the aluminum one.
5). The converter will be locked.
My dyno tune appointment is today at 4PM so get your guesses in today and I'll update the results tomarrow morning.
Also I'm hitting the track tomarrow night for new track numbers. Numbers in my sig was before cam, fast 90 and UD pulley. I run 255/50R16 MT street radials. Guess my new track times also if you like. Track is 900 feet above sea level and weather will be in the 60's.
LS1 Tech Administrator
388/379 rwhp/rwtq if your dyno is honest/representative of other Dynojets.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
I'm thinking 11.7 for ET.
I am planning on 6500 shiftpoint. I would love to spin to 6800 but I'm too worried about the stock rod bolts.
quick question , how do you lock the converter on the dyno? i was on the dyno last night and i needed to do this and couldnt think of a quick solution. i have hp tuners but didnt see a place to do that?
The results are in and they were a little disappointing. The best my car could make with the converter locked was 380 rwhp / 340 rwtq. With the converter unlocked I made 354/322.
I have a friend with a 98 Formula with 3.42 gears, LT's, TCI 3000 stall, V1 streetsweeper (228/232 111), BBK intake, UD pulley and street tires. His car made 353/330 on the same dyno. So with the bigger cam and better intake I made a whopping 2 rwhp more BUT 8 rwtq less.
According to the tuner my drag radials and looser stall both attributed to my numbers being so close to Johns. He seems to think my car will shine at the track. We are all going tonight so I'll be lining up against my buddys car and we'll see how they compare. His best so far is 12.0 @ 112.
yeah, dynos are cool if you got high numbers or somethin, but the real deal is at the track. i bet you will put down some sick times and wont give a **** what that dyno sheet says. post up the results man. you will see some 11s. good luck
Dont get stuck on numbers man. My friends H/C car only made 360 unlocked on a mustang dyno and it ran mid 11's. And thats with stock 3.23 NO suspension mods and drag radials.
Take it to the track and I doubt you will be disappointed.
Just got back from the track. Temp was in the 50's so all times were better then average due to a very favorable DA. Best pass tonight was:
11.93 @ 114.40 on a 1.68 60'
My buddy John ran 11.95 @ 113.80 on a 1.67 60'
We both have identical bolt ons. But I have a 5C 4400 stall to his 4C 4000. I have a fast 90/90 to his BBK and stock 78mm TB. I have a 236/240 cam to his 228/232. I'm shifting at 6600 rpm's to his 6200 rpm's. Plus he has a 98 with even worse heads then I have.
For all intensive purposes I should be a few tenths quicker and a few mph faster. But we are within less then a tenth in ET and less then 1 mph in trap. Plus all the guys at New Era said 354 (unlocked) was the lowest number they have ever seen a streetsweeper/fast 90 make.
My problem is that this setup did not make the dyno or track numbers it normally does. And if I don't do anything about it now then next year in June, July & August I'll be running 12.1's @ 112. F that. If the compression check goes ok then that cam is coming out and being replaced with one that won't be an underachiever.
I hope!
I hope!
But that's neither here nor there as far as I'm concerned. The trap speed is why this cam only setup is an utter failure. But one way or another the situation will be corrected.
Looks like good runs though. Especially considering you were disappointed with the numbers. Congrats. Goes to show the dyno doesn't tell the whole story!
Personally I think the runs sucked. That setup should be good for 11.6 @ 116 in last nights air. The cam didn't perform on the dyno and likewise it didn't perform at the track.
