TR230+ bolt on dyno #'s
Mods are
ls6 intake, slp lid, UD pulley, Longtubes ORY w/SLP dual dual, 230/224 cam. Tuned.
LS7 clutch/ls2 flywheel, steel drive shaft w/ a 12 bolt and 3.90's.
The car is tuned pretty conservatively because of it having almost 90k on it.
made 385rwhp and 367 rwtq. the airfuel was at 11-1 which i know is real rich. I was kinda disapointed but o well. ill post the graph when ive got time.
Not to bad. What type of longtubes? 11.1 is way to rich. Tuning conservitive is fine but you should be around 12.5 to 13 at the most for a n/a build. If you add a p/p throttle body and fix your a/f you should see 390+hp and around 375tq.
1 Post
I would say the tuning is not done if you are at 11:1...you need to be at 12.5 - 13:1. You are in the boosted application range right now. You could run 10 pounds of boost with that AFR.
LSX Mechanic
People are neglecting to notice you have two HUGE power robbing mods in your car. The LS7 clutch, which I've personally seen make a car lose 13 rwhp on the dyno, and a 12 bolt. With a stock clutch your car would be in the 400 rwhp range, and prob 415ish rwhp or so through the 10 bolt.
Considering the drivetrain, those are great #'s
