Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Crappy luck still PREVAILS AGAIN!!!! Big let down inside!
Old 12-12-2009, 04:15 PM
Zturd's Avatar
Default Crappy luck still PREVAILS AGAIN!!!! Big let down inside!
Well after busting my hump to get easyvettes 18x11 chrome C5Z06 wheels on the back, with a thin spacer, changed clutch fluid reservoir twice before the trip I went to bed at 1am last nite and couldnt sleep seemed like it was gonna be better then Christmas. Well we go down with carefully estimating fuel to come in at just under a 1/4 tank of gas. BFG 315 drag radials 5yrs old set at 25ps. I line up the car after seeing several cars break and several sliding all over the track. I pull up do a very small burnout cause I thought OMG clutch is letting go but the car just power brakes alot easier then I thought. So I rolled up to the lights. 3000rpms and let the clutch come out as I rolled into the gas a little to slow and she fell then started to spin. Quick shift to 2nd and get some more tire spin through alot of 2nd gear lightly hit the rev limiter and shift to 3rd and then 4th gears. Get my timeslip of the first pass in the car
2.011-60ft
5.275-330ft
7.846-1/8mi
96.31mph
10.006-1000ft
11.833-1/4mi
123.32mph
I was bummed but looked at as all the things that were completely wrong and how easy it was going to be to improve these things. So i immediately come back around and go for another run after sitting in line a bit and some more breaking and waiting car is sitting 217* and i've read and heard thats just fine and normal. So I pull up do a much better burnout with tires at 21psi now. Launch and I bog with another 3000rpm launch. Rolls out and hit 2nd gear decently light spin and then the rpms come up and it kinda feels weird... then 3rd gear and now feels really bad but pulling through the gear but i go through the traps at 111mph at 12.18. I was completely confused. I pull into the pits check over things and wait for a friend with HPtuners to check for codes though the check engine light did not come on. So check and no codes, look things over and more confused when i get on it, at approx 5k rpm the car falls on its face. So i'm like well maybe its the competitive driving mode causing it. I try to turn it all off and realize I can now only turn traction control on and off and doesnt give me a competitive mode on or off. So I go put more gas i thinking its cause the car is low on gas. Nope wasnt it, tried pulling the negative battery cable for 10minutes, nope didnt change, drove the car around to see if it would reset or something. Never did figure it out. Sorry everyone we'll getter figured out since the car is 100% stock and getter all taken care of and come back stronger and better then ever next year. Thanks for all the interest/support.
Bruce
Old 12-12-2009, 04:58 PM
10flat's Avatar
Default Waiting for you
We'll do the first run next year
Ron & Carlos
Old 12-12-2009, 05:10 PM
Devilish34's Avatar
So for one day my 4000+ lb four door is faster than a 3300lb 08 Z06.
Hopefully you find out what happened
Old 12-12-2009, 06:47 PM
Frans96SS's Avatar
They weigh 3130
Old 12-12-2009, 07:02 PM
LS123's Avatar
Hey Turdy, sorry I wasn't there long enough to help out. I really wanted to see what the base line was pure stock! Oh well, let's start early next year see what we can improve on. Also when you bring it down to me?
Old 12-12-2009, 07:34 PM
Devilish34's Avatar
Originally Posted by Frans96SS
They weigh 3130
I was being nice and adding Bruces 170lb body weight to the cars
Old 12-12-2009, 07:35 PM
Devilish34's Avatar
I need to get a G8 diff down to you for you to look over and offer opinions and options..
Old 12-12-2009, 07:43 PM
LS123's Avatar
PM sent.
Old 12-12-2009, 11:53 PM
1bigcam's Avatar
sorry to here about the bad luck, get that 60 foot down and some more track time, it will go much much faster
Old 12-13-2009, 07:00 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Sorry to hear you didn't get exctly what you were hoping for, but I wasn't too far off guessing a 11.55 @ 126 spinning through first and second.
Old 12-13-2009, 08:06 PM
2ktransam's Avatar
I didn't want to say it yesterday but so is my 5,300lb truck. LOL
I hope you get it figured out Bruce. That really sucks that you are having problems with a bone stock car. Good thing is that they come with a warranty. Get it figured out and we will head back down in the Spring to see what all of our new setups will do.
Old 12-15-2009, 11:42 AM
CamaroSS621's Avatar
sounds like zturd needs the most important mod of all... driver mod. lol
you do know I ran 11.23 @127 stock right??? haha
ok im done busting your ***** for now.... hey atleast you didnt break this time right?
Old 12-15-2009, 02:00 PM
CARTEK Racing
WS6TransAm01's Avatar
must have been those dumb *** Punnisher stickers... Car did not like 'em and decided to implement a 5000rpm rev limiter....
Old 12-15-2009, 06:18 PM
Zturd's Avatar
I think you're right.... wait whats your 2yr sebatical sorry *** excuse? With love.
Old 12-22-2009, 10:07 AM
BlueStreak362's Avatar
did you get a chance to use that HPT to log the car for a pass?
Old 12-22-2009, 10:10 AM
dschmittie1's Avatar
No I was using the HPT to log another car that day. We did however go out with a TECH 2 the other weak to see it pulling 10degrees of knock retard above 5k. Should be going to the dealer to get fixed in a weak or so. Apparently it has something to do with the Alternator. Crazy ****.
Old 12-22-2009, 02:47 PM
CARTEK Racing
Well I figured my old H/C numbers embaraced you so much I would give you time to catch up... but it looks like you gave up knowing you just suck at life.
Old 12-22-2009, 03:58 PM
any DTCs set? you could look at the freeze frame on the Tech2(if its still saved) if they were. Somthin with the alternator is crazy, keep us updated im curious
Old 12-22-2009, 04:06 PM
wonder if it has a bad knock sensor.. any DTCs set? you could look at the freeze frame on the Tech2(if its still saved) if they were.
No DTCs and its not a bad knock sensor. Shows random knock on multiple cylinders and has been through several tanks of gas. But word from a Vette specialist says he had one that a bad alternator caused this. The car is still under warranty so the dealer has to fix it. But I don't work at a Chevy Dealer so I can't help him out Bruce just stopped by my work over lunch one day to check it out quick. But I am no spring chicken to working with a Tech2 and freeze frames.
Old 12-22-2009, 07:42 PM
hm, maybe regulator acts up at high rpm causing bad voltage spikes? i honestly have no clue thats weird, and the Tech2 and Snap On Modis are my two fav's to use freeze frames are easy to review, and pretty cool having a oscilliscope on the snap on too.
