Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
FS MOSER 9" ***Local Only***
Old 06-22-2006, 04:06 PM
Fireball's Avatar
Talking FS MOSER 9" ***Local Only***
What I have:
9" Moser housing (standard length)
Strange Pro-series Nodular iron center section (big bearing)
Detroit Locker
35 spline axles
drain plug installed
Relocation brackets installed
Sway bar mounts welded on
Latest revision of Moser TA bracket
1/2" screw in wheelstuds
1350 yoke
Backing plates are included and installed.
4.71 gears installed, but I will give a set of 4.30s and 4.56s with the package deal
I don't know how noisy the gears are since I've used it only for racing the last 2 years. One quirk with the setup is I put the backing plates on the wrong side. This doesn't hurt anything, just the calipers are on the opposite side of the rear from OEM.
This is plug and play, ready to bolt in.
$2000 (will not ship)
Will include a BMR XTREME DRAG rear swaybar (all parts except the weld in mounts on the car, have to buy new ones from BMR) for an additional $250
Located in Northeastern MD. 6 miles from Cecil Dragway
Old 06-22-2006, 08:22 PM
choppin-suey's Avatar
Originally Posted by Fireball
What I have:
Detroit Locker
35 spline axles
1350 yoke
$1700?
Old 06-22-2006, 09:00 PM
Fireball's Avatar
There is 2700+ in stuff here. Its 2K or nothin
Old 06-22-2006, 09:07 PM
ATVracr's Avatar
You can keep all 3 sets of gears for your new rear he wont need those.
Old 06-23-2006, 05:33 AM
Fireball's Avatar
I can work something out for the housing, axles and locker since I'm not reusing any of those parts in their current form
Old 06-23-2006, 02:11 PM
come up with something and let me know......
Old 06-23-2006, 03:01 PM
Fireball's Avatar
Housing with relocation brackets and drain plug
35 spline axles with LS1 backing plates, 1/2 wheel studs and bearings
35 spline detroit locker with carrier bearings
$1200
Old 06-23-2006, 06:14 PM
SSmokedya1320's Avatar
where do you live!
Old 06-23-2006, 06:28 PM
Fireball's Avatar
Rising Sun, MD.
Old 06-23-2006, 06:45 PM
02SOMWS6's Avatar
$1200
fugggg, where was this deal before I did 4.30's and a spool for my 12 bolt. I was more than half way there in price between gears ,spool,install kit ,etc. Thats a good deal
Old 06-23-2006, 09:35 PM
Mr Gadget's Avatar
$1200
so no center section, pinion support or yoke?
Old 06-24-2006, 07:11 AM
Fireball's Avatar
no center section case, no support, yoke, or gears for 1200.
only differential (detroit locker), housing and matching axles.
Old 06-26-2006, 07:04 AM
Fireball's Avatar
ttt
