Lashway Motorsports, Inc. is now an authorized distributor of Monster Clutches!
Lashway Motorsports, Inc. of Pompano Beach is proud to announce that we are now authorized distributors of Monster Clutches!
We are the ONLY distributor in South Florida that has these clutches in stock and ready to install on your vehicle at a great price! We carry the full line up of Monster Clutches for your convenience. Just give us a call and we'll get you set up!
Below is some info on the popular Level 3 Clutch/Flywheel Package that we will carry in stock here at the shop:
Now we’re talking! This thing is the pinnacle of cera-metallic clutches! Want a clutch you can throw 700 hp/tq at without batting an eye? Want a clutch you can feel confident launching a 4,000lbs car at 5,000+ rpm on? Want something that will take a beating at the track and keep begging for more? Look inside.
Here it is, our most popular clutch we make! We take one of the best pressure plates in the industry, we team it up with our 12” 6 puck cera-metallic disc, and we squeeze it together on a SFI certified billet steel flywheel. You can be sure that there is no other single disc clutch on the market that drives like ours, takes a beating like ours, and will keep ticking like ours for many miles to come. The clutch material that we use has one of the best coefficient of frictions on the market, that mixed with our Heavy Duty pressure plate make this clutch almost unstoppable! We rate this thing at 700hp/tq with extreme confidence! Have a car that frequents the track and makes less than 700hp/tq? This is your clutch! Like to launch on slicks at 5,000+ rpm? This is your clutch! Want to do all that and drive home? This is your clutch!
This clutch is rated at 700hp/tq. It will take a beating no matter what road surface you are on. The cera-metallic material has a superior coefficient of friction and will take just about anything you can throw at it. This clutch should be used aggressively, no matter what. The only warning we have for you is this; if you make this kind of power and you have a weak drive train, you will break stuff! This thing finds the weak points and lets you know!
The Basic Package includes the following:
H.D. pressure plate, 12" cerametallic 6 puck disc, 28lbs SFI certified billet steel flywheel or a 18lbs SFI certified light weight flywheel (your choice), pilot bearing, release bearing (unless it's the C6 package), and alignment tool.
The Premium Package includes the following:
H.D. pressure plate, 12" cerametallic 6 puck disc, 28lbs SFI certified billet steel flywheel or a 18lbs SFI certified light weight flywheel (your choice), pilot bearing, release bearing, slave cylinder, and alignment tool.
Call, email, or PM us today to order yours!
Nice. I put one in my car over the winter. BADASS setup. I launched it at the track last week and it took a beating and then drove home with no issues at all. Plus one for Monster.
