317 heads & LS6 cam...
Old 10-20-2008, 01:05 PM
ss.slp.ls1's Avatar
Default 317 heads & LS6 cam...
Would it be worth the time and the money to swap those heads and cam onto an otherwise stock LS1 with a procharger? Trying to stay budget friendly is the key. Anyone know what kind of gains to expect with a tune? Thanks for the help.
Old 10-20-2008, 01:19 PM
1320's Avatar
its not the gains persay, its the longevity. 317's lower the compression and if you do it, budget for gm mls gaskets and 12 point arp studs.
Then once you get the iat's down with an intercooler/water meth you could re pulley it for more boost then you would otherwise ever get to without the heads. The cam, they are nice for the price especially on fi. They like some rpm as well which your procharger will appreciate as well.
or switch to e85......which leads to injectors, tuning, and pumps, so its pretty much a wash $$$ wise probably.
Old 10-20-2008, 02:58 PM
98Z28MASS's Avatar
If its cheap then id say its worth it. As stated above the 317's will lower your compression and the ls6 is a good FI cam, so i think if it is cheap enough then id do it. While swapping in the cam though id upgrade your valve springs to minimum comp 918's but preferably some patriot duals. Also, you wont gain anything by simply making this swap. You will need to get a new pulley for the procharger to increase the boost as by lowering the compression you can now add some additional psi to your setup.
Old 10-20-2008, 03:05 PM
headed-ws6's Avatar
I would swap them out you wouldnt see much if any gain N/A But you would be able to run more boost safer and in turn more hp. I say if you can get them for a good price do it.
Old 10-20-2008, 03:12 PM
ss.slp.ls1's Avatar
Ok, consensus is if the price is right, do it and that the real gains are from a new pulley. I have seen LS6 cams + springs for as cheap as $150 + shipping and I have seen 317's for $200 + shipping. Once you factor in the price of gaskets and fluids, still worth it?
Old 10-20-2008, 03:47 PM
1320's Avatar
The head studs are 239.........and gaskets about 70........but if you do it, do it right.
Old 10-20-2008, 03:48 PM
SStolen's Avatar
Yes! Thats a great budget set-up. But get heads, springs, pushrods, ARP Head Studs, and GM MLS gaskets. Should run you around $1000 all said and done. And if you can't aford that then you shouldn't be bothering with forced induction anyway. It's not really negotiable, you need that stuff. Tune it for 8lbs or 550rwhp or so and be done with it. Should last you a long time.
Old 10-20-2008, 03:54 PM
ss.slp.ls1's Avatar
Understood, is it true that 918's would be the minimum springs to use?
Old 10-20-2008, 06:07 PM
SaultysHuggerSS's Avatar
And if u are getting a good price on 317 they are porb used so make sure the are in good condition not to mention resurface and lapping the valves while your at it
Old 10-20-2008, 06:17 PM
30th t/a's Avatar
Im running the 317s & the LS6 cam in my forged 347. I like the setup alot. Cheap and effective. I was planning on running 15psi right off the bat but with my base line tune and 10psi, this car flys. I need better tires before I even think of bumping it to 15psi.
Old 10-20-2008, 06:22 PM
SStolen's Avatar
Comp 918's are fine. Even though you might be putting down 500+rwhp, the LS6 cam is mild in that it doesn't have a lot of lift or aggresive lobes. They'll be able to handle the limitations of the stock block anyway.
Old 10-21-2008, 04:15 AM
tomz28's Avatar
i run 317s and a 04 ZO6 cam and i have made as much as 694 at 12psi on stock bottom end. its more like 650rwhp that dyno was alittle high
i think you will like them i do and it works good on the street
good luck and have fun
Old 10-21-2008, 08:57 AM
rufretic's Avatar
I have a set of 317s for sale that would be perfect for you, they are bare so very cheap and you would want to upgrade to better springs with the cam change anyway.
https://ls1tech.com/forums/lsx-parts-sale/1004300-bare-317-heads-cheap.html
Old 10-21-2008, 09:44 AM
98Z28MASS's Avatar
Comp 918's will suffice but id look at the patriot duals as they will provide you extra protection in case a spring breaks and they arent that much more price wise.
Old 10-21-2008, 09:49 AM
ss.slp.ls1's Avatar
Thanks for the help so far fellas. So I guess after the heads and cam, comes a new pulley, meth/water injection, and tuning.
Old 10-21-2008, 01:29 PM
Fb0dy0nly's Avatar
You dont need duals on that small of a cam. With springs there is such thing as too much as well as too little.
Old 10-21-2008, 01:46 PM
tomz28's Avatar
i went duals because of the boost
Old 10-22-2008, 12:48 PM
98Z28MASS's Avatar
True, I have seen individuals run comp 918's on some very radical cams, however they had to be shimmed properly. On a boost setup, id only suggest duals just as a safety measure, JMO though.
Quick Reply: 317 heads & LS6 cam...
