Which turbo for Autocross?
Old 11-19-2008, 01:26 PM
efinifd3s's Avatar
Default Which turbo for Autocross?
I've finally decided to ditch nitrous and go with a longer lasting power adder: turbo induction. My main concern is spool time & low rpm response. The car will occassionally see the drag strip.
My current engine mods are stock 346ci shortblock (LS1), AFR 205 (66cc) heads, 214/230 .601/.575 117 LSA cam, FAST 90/90, cometic hg, APR fasteners. The car will have a 4" turbo-back exhaust system.
My questions are:
1. What turbo offers the best compromise (top-end power vs throttle response) for autocross/auto-X events on 4.10 gears.
2. Should I change out my cam?
3. What horsepower can I expect out of 6psi on the recommended turbo?
4. Is there any hp to be had for dumping the wastegate in the atmosphere versus back into the downpipe?
Old 11-19-2008, 02:01 PM
67Firebird455's Avatar
That cam will work with such a high LSA, you're only going to run 7-8 or so psi doing autocross, and I'd go with a smaller turbo, well, as small as you can go since you'll need faster spool rather than higher psi. I think a setup like that would make somewhere around 575rwhp.
Old 11-19-2008, 02:33 PM
GT67METHV's Avatar
a gt67 is good from mid to high 4's at 4-6psi. to over 6oorwhp at 12-14psi.
Old 11-19-2008, 04:34 PM
sultan(ZR-1)KSA's Avatar
twin GT28 u cant beet that responce
Old 11-19-2008, 05:26 PM
LS1Tech Sponsor
Mike@Diablosport's Avatar
You should be around 425-440 rwhp right now, correct?
Adding 6-8 psi from a small (properly sized) turbo should get you well into the 600 rwhp range.
Not sure about those 4.10s though....may want/need to go down to a 3.42 or so with all the torque you'll be making.
Old 11-19-2008, 07:40 PM
LS1TECH Sponsor
DrTurbo's Avatar
TC70. We have a customer now running SCCA with a TC70 on a stock cube forged 6 spd car. Car is awesome.....just have to get a big enough turbine wheel to keep the EGT's down. Under sustain throttle, that is the major problem.
Old 11-19-2008, 10:33 PM
Gingervitis Addict
slow67's Avatar
What about a water cooled turbo? Also, all the autocrosses I have been to, the run is less than a minute to a minute and a half.
Old 11-19-2008, 11:17 PM
AVB
AVB's Avatar
Old 11-20-2008, 08:31 AM
efinifd3s's Avatar
Yes, at its current state, the car makes about 430 rwhp w/o nitrous. Because I'm still using the stock rearend (1993 Rx7), the lowest gearing that would fit is 3.90 from the diff of an automatic Rx7. I could go lower if I swap in a cobra IRS.
Besides the already mentioned gt67, are there other relatively small turbos that could make 600whp w/ a fast response? If going with a slightly larger turbo is more efficient, I'm assuming only the large turbos with the ceramic ball-bearing option would produce 600whp with the spool time of a small turbo. Is the ball-bearing turbos worth the extra money versus buying a smaller turbo? Would my stock shortblock be able to handle the extra CFM's of a larger BB turbo at 6-8psi?
Old 11-20-2008, 09:01 AM
matt_paco2010's Avatar
What you're talking about is boost threshold. Don't get screwed into buying a smaller turbo just because you want to lower your boost threshold because you'll be killing your motor at higher rpms. This includes restriction and huge heat buildup. Always err in the side of a bigger turbo.
Water cooled bearing journals are great. The turbo is oil lubricated, but it has water jackets around the bearing that almost prevent mineral deposits from coking up the bearing.
A change in cam would help and going back to stock would be awesome. The LSA is a killer because when the exhaust valve stays open longer it causes reversion into the combustion chamber which is a BAD thing. Honestly the stock cam is about the best thing you can do on almost any turbo build, they're so turbo friendly.
Old 11-20-2008, 11:25 AM
LS1TECH Sponsor
DrTurbo's Avatar
EGT's under WOT climb very fast and have to be addressed when the motor never comes down off 4000-4500 and up rpms. Drag racing and runs of just WOT for short period of time is not a big problem. Scca and even worse is our road racing customers. They by far are the hardest on turbos of any of our customers.
Old 11-20-2008, 02:33 PM
52172's Avatar
what the biggest turbine wheel that can fit in the TC units? I have an MPS wheel is there something better for backpressure and heat?
Old 11-20-2008, 02:45 PM
LS1TECH Sponsor
DrTurbo's Avatar
That is the biggest. BUT you can go to a larger A/R twin scroll housing...
Old 11-20-2008, 03:56 PM
94 slow's Avatar
What else can someone do to keep the EGT's down while road racing? I wanted to run a TC 78..but...
Old 11-20-2008, 04:01 PM
LS1TECH Sponsor
DrTurbo's Avatar
It will run just fine. You can do water cooling on the TC series turbos. We offer it FREE of charge if you want it.
Old 11-21-2008, 07:56 AM
Tricked-Out-Toy's Avatar
I seriously wouldnt build your "turbo" setup for autoXing. I autocross and back before my turbo on about 380hp I was destroying the track N/A. on tight short autoxcourses where you only WOT for very very short periods next to no boost would be the best. I plan on running the least amount of boost possible when i autoX. Now roadracing ill be cranking it up and seeing what she can do.
On the water cooler Topic, I just recieved my TC-78, what are the advantaged of doing water cooler? should I have went that route since ill be road racing?
Old 11-21-2008, 12:23 PM
LS1TECH Sponsor
DrTurbo's Avatar
Advantage is, the water will keep the rear bearing cooler. That will prevent coking.
Quick Reply: Which turbo for Autocross?
