F1 Procharger vs. Vortech YSi
Old 12-03-2008, 11:14 PM
bluebird71's Avatar
Default F1 Procharger vs. Vortech YSi
I am going to install a big centrifugal blower on my car sometime in the next year. My motor is already built for big boost so I'm looking to make around 900+ to the rears. I was planning on going with an F1 Procharger but have also recently been looking at a Vortech YSi as well. I'm just trying to get a good comparison of the two like... which has more boost potential, which is quieter, is one more street friendly than the other, does one sling belts worse than the other, and so on.
Old 12-04-2008, 01:47 PM
BLNLS1/RX7's Avatar
Except no subsitutes,go with the ProCharger.
Old 12-04-2008, 01:51 PM
Grr
Grr's Avatar
I had the YSi, and i think the procharger is a way better option. The YSi is very quiet and durable as hell, but it has a terrible step up ratio. This makes setting up pullies very difficult as i was running a 2.75" to get decent boost. With the F1 you would be in the 3.25" range making belt life much better. Thats my $.02
Old 12-04-2008, 02:19 PM
SLOW30th-TA's Avatar
Subscribing to listen....is the F1 to big for a 347?
Old 12-04-2008, 06:39 PM
bluebird71's Avatar
Does anyone know if either the Vortech V-7 or the self contained V-3 will fit an f-body.
Old 12-04-2008, 07:19 PM
2001WS6Vert's Avatar
RMCR (Rocky Mountain Competitive Research) sells a bracket kit for the YSi, a cog drive to if interested. You do have to cut some of the underside of the hood and it's best to relocate the coils with the Thunder Racing kit.
Old 12-05-2008, 09:11 AM
Dumb Ass Vette Moderator
ls1290's Avatar
The F1 and YSi are very close units in specs and performance. Now a F1-R is a completely difference story
Old 12-05-2008, 10:33 AM
98Z28MASS's Avatar
I dont think so as I believe Bob at EPP and KP were running F-1's on stock cubed motors.
Old 12-05-2008, 11:45 AM
DanWS6's Avatar
I'll let you know as soon as we get my tune dialed in.
Old 12-05-2008, 06:15 PM
flawless35th's Avatar
RMCR is bad *** im pretty sure they can mount the cog setup ysi at the driverside bottom of the engine
Old 12-05-2008, 07:03 PM
A pic of the RMCR cog drive.
Old 12-25-2008, 06:35 PM
stevieturbo's Avatar
What sort of pulley gearing are they using there ? teeth crank/blower ?
Old 12-25-2008, 08:21 PM
bluebird71's Avatar
I'm looking for the metal air intake lid that Vortech makes, but I can't remember where I saw it. I looked on their site, but I couldn't find it. I want to use it to retain the use of the ram air no matter which kit I end up getting.
Old 12-26-2008, 07:17 AM
ss1
ss1's Avatar
I think the lid you're looking for is the one 2001WS6Vert has on his car. It's a custom made lid from RMCR, not a Vortech item.
Old 12-26-2008, 11:01 AM
venom ws7's Avatar
Get yourself F1A From EPP with FMIC the car should be 700+rwhp with mid boost and pump gas then you can run more boost and race gas you'll be close 900hp.
Oh is that Patrick G's old car???? it looks awesome.
Old 12-26-2008, 03:27 PM
bluebird71's Avatar
Thanks man, yeah it is and I am trying my best to keep the car looking and performing to the highest it can. For budget reasons, I have been giving some thought lately to just going with a D1SC because this car is mostly street driven anyway and I think it could still make impressive power and be able to run pump gas all the way through (maybe with a little meth/water injection) with a maxed out D!SC.
Old 12-26-2008, 04:49 PM
1bad lad's Avatar
you are ganna wear out that d1sc more wuickly with it turn all the way up all the time....get a bigger blower such as the f-1a and thisway it won't be so hard on it. the f-1 also has the larger step up ratio
Old 12-27-2008, 02:03 AM
bluebird71's Avatar
Originally Posted by 1bad lad
you are ganna wear out that d1sc more quickly with it turned all the way up all the time....get a bigger blower such as the f-1a and thisway it won't be so hard on it. the f-1 also has the larger step up ratio
I have seen cars with D1SC setups make over 800 rwhp before. I figured the D1SC would be more steerable in that it will run cooler and not be quite as super noisy. I don't want a supercharger that will pierce my ears while I'm driving in traffic. Is the Vortech a little quieter?
Old 12-27-2008, 11:12 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Accept no substitutes. Go with the Procharger.
Sorry, I had to fix that one.
The following users liked this post:
Johnny_M (11-24-2022)
Old 12-28-2008, 01:09 PM
sykodrummer9800's Avatar
I agree with Urban Legend...Accept no substitutes. Go with the Procharger.
Quick Reply: F1 Procharger vs. Vortech YSi
