Procharger+ nitrous?
Old 01-19-2009, 07:27 AM
ELMiN8oR's Avatar
Default Procharger+ nitrous?
I've always wondering is it possible to use 75 shots on 347 running 15psi on a D1SC?
Current setup:
forged 347 9.5 compression ratio
stock LS1 heads
226/228 113+3
Old 01-19-2009, 07:35 AM
deuce_454's Avatar
just be sure you have enough fuel, and pull timing accordingly.... but anything is possible.. it will put additional strain on the engine, tranny, rear etc... so eventually somthing will break. so if its sensible is up to you really
Old 01-19-2009, 11:17 AM
nichols92's Avatar
How much power are you trying to make? I dont think you will need it once the D1SC goes on.
Old 01-19-2009, 11:45 AM
Drewstein's Avatar
I threw a 100 shot on my D1 equipped 402 so I say go for it. Pull a little timing and check it on a dyno, but it will pick up a lot and pull like crazy.
Old 01-20-2009, 02:28 AM
chuntington101's Avatar
how much more power did you make when spraying over to just boost?? i hear you can make about 150% of the shot (thanks to cooling of the intake charge)!
Chris.
Old 01-20-2009, 04:47 AM
Mr.Big's Avatar
Go for it!!! I can't (don't want to) spray mine at the current level, It was fun to use in the past, but at the current level I don't want to push the stock short block above 850, I just don't have enough faith that she'd take it...
Old 01-20-2009, 06:37 AM
Mr.Big, same question ton your mate, how much power did you make on the gas and on boost only?
Chris.
Old 01-20-2009, 11:44 AM
BLNLS1/RX7's Avatar
How were you able to get 15 lb. of boost out of a D1SC?
Old 01-20-2009, 03:22 PM
Mr.Big's Avatar
Chris.
Chris 761rwhp no N2O now, when I last sprayed the car she was only making 620rw on boost, and she'd make an extra 120rw on the juice (100 dry shot)... but now at 761 If I spray it that'll put me at ~880rw, and I know the stock short block won't like that much...
Old 01-20-2009, 04:16 PM
bigsticksupra's Avatar
wouldn't the instant power/torque from nitrous cause the belt to slip? or is this not the case
Old 01-20-2009, 06:33 PM
Floader's Avatar
not gonna happen.... hitting the spray wont rev the motor an faster than hitting the gas in 1st an spinning the tires
Old 01-21-2009, 10:08 AM
Drewstein's Avatar
Chris.
I think due to the bigger cubes I may benefit more than you, but I picked up 250rwhp so far on a 100 shot. Went from 700rwhp to 950rwhp while still pretty rich. I had 800rwhp by 5000rpm on the spray. Best part is running 91 octane with 109 in the fuel cell.
Once I get my new fuel pumps and the flip drive in I'm going for 1000rwhp.
Old 01-22-2009, 02:24 AM
Bloody hell mate! that is some gain form a 100shot! lol
be nioce tio see the intake temps before and after spraying to see just how much cooler the intake is. shows how much power could be had with more efficent intercooling.....
be nice to see someone REALLY pushing their FI setup with N2O. has anyone ever run say a 250shot into a boosted LS motor??? if it netted you say 400bhp a 600bhp DD could turn into a 1000bhp monster with a little gas.
Chris.
Old 01-22-2009, 08:50 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Remember when you start to mix power adders, their overall affects are not cumulative. I have seen many FI setup put on a 100hp shot and pick up 150 to 175 rwhp. When you do mix them, you need to make sure you tune is right on or your car will be a ticking time bomb.
Old 01-22-2009, 09:28 AM
Drewstein's Avatar
This is true. I already backed my timing down so I'll only dyno 700 or so rwhp as opposed to my 750 on 91 octane. This way I grab the kit, only 100 shot, that has it's own 109 fuel supply for more safety. I also went to a colder plug.
Old 01-23-2009, 02:25 AM
totally understand that! there is alot of gains to be had form the cooling benifits alone with N2O. shame there is no way/system to just have have the cooling benifits.......
Chris.
Old 01-23-2009, 02:33 AM
I think its a great idea! should keep things nice and safe when spraying.
whats your feeling on the effect of N2O on the motor compeard to more boost? would adding a 100shot (ok it will be adding more pwer than that) to make say 1000bhp be safer than upping the boost to make the 1000bhp?? would it be easier on the motor?
thanks
Chris.
Old 01-23-2009, 03:16 AM
c0ncEpT's Avatar
thanks
Chris.
I think your tune is going to have to be spot on in either situation. Like others have said its going to be even more important when you start throwing 2 power adders in the mix.
I also don't think your going to be able to hit those numbers with a 347 and a D1SC without nitrous. Your going to have to step it up to a bigger blower and motor to get numbers of 1000+ IMO.
Old 01-23-2009, 07:11 AM
ELMiN8oR's Avatar
I'm aiming 550+
but I was thinking what if I combine two power adders what will be the result?
will the rings hold these two power adders?
Old 01-23-2009, 12:09 PM
Drewstein's Avatar
whats your feeling on the effect of N2O on the motor compared to more boost? would adding a 100shot (ok it will be adding more power than that) to make say 1000bhp be safer than upping the boost to make the 1000bhp?? would it be easier on the motor?
thanks
Chris.
The problems that arise with upping the boost to reach your goal sometimes can only be resolved by running good fuel. With that said, the D1 is good for 700rwhp on 91 octane without over spinning it which is far past your goal. The N20 is there when there isn't any more D1 left.
In order for me to make the jump from 750rwhp to my goal of 1000rwhp with only boost, I would have to get a new head unit, bigger injectors with the corresponding controller, maybe new manifold and who knows what else. Then to do it on pump may still not have been enough.
I think the motor can't really tell where the air is coming from whether it be compressed or a gas. Therefore, I think it's best if you reach your goal with boost first, then add on when you're maxed or you're wasting money.
Quick Reply: Procharger+ nitrous?
