question on 317 heads
Old 02-14-2009, 12:44 PM
Taubr Unit's Avatar
Default question on 317 heads
Is there any certain year to buy? I have a line on 2 sets. Are there different models for different years, one better then the other to use?
Old 02-20-2009, 01:23 AM
SD99TA214's Avatar
im wondering myself , on here searching now...........anyone with a link to a thread, youd be awsome.
Old 02-20-2009, 07:32 AM
calongo_SS's Avatar
Aren't the older ones iron? Not sure if those are 317' or not though, probably a different casting number.
Old 02-20-2009, 07:48 AM
Photochop's Avatar
I think you want the most recent ones you can find...as long as they're 317 casting number and aluminum, they should be what you want. I think I heard a rumor at one time or another the later 'version' ones were redesigned to match the LS6 head port design.
Old 02-20-2009, 07:58 AM
ElectronSS's Avatar
01+ are what you want.
Old 02-20-2009, 11:35 AM
sujomatt's Avatar
How can you even confirm the year if you have a set? lol
Old 02-20-2009, 12:28 PM
SD99TA214's Avatar
wait so on a 317 you cant normaly run a ls6 intake???? now im getting confused.
Old 02-20-2009, 12:39 PM
Photochop's Avatar
317 is the cylinder head casting number. You can use an LS6 intake manifold with these heads. I was referring to the 317 cylinder heads being a similar port design to that of the LS6 cylinder head, which is why the 317 heads are a cheap 'bang for your buck' head used on many forced induction motors. They not only decrease compression due to their larger combustion chambers, they flow very well too for a factory GM casting.
Old 02-20-2009, 12:47 PM
SD99TA214's Avatar
ok thats what i figured....just makig sure.. thanks for the info. so on a typical chamber smoothing, on a stock ls1........whats the general cr?
Old 02-20-2009, 12:49 PM
viper9403's Avatar
The 317 heads with the "triangles" on the casting of the exhaust port side are the better ones....They are the same casting as the LS6 head with larger chambers. 71.4cc to be exact
Old 02-20-2009, 01:20 PM
Photochop's Avatar
Gotta look for those triangles tonight...I'm not sure which ones are on my motor besides that theyre aluminum and have the 3-1-7 on them and came off a 6.0 liter
Old 02-20-2009, 01:29 PM
TurboAv's Avatar
The 317's and 243's are the same ports, just different combustion chamber sizes.
Old 02-20-2009, 02:09 PM
sujomatt's Avatar
Totally misread, nm this stupid post i just left. lol
Old 02-20-2009, 03:22 PM
ElectronSS's Avatar
underneath the head in were pushrods slide thru there are casting numbers for specific years on all of Gm heads
Quick Reply: question on 317 heads
