truck manifolds, can you mount them upside down?
pretty sure you can reuse the stock LS1 alternator bracket when relocating it to the head. There was a recent truck manifold thread where the thread starter reused it with good results.
here:
https://ls1tech.com/forums/forced-in...old-build.html
J
here:
J
here:
J
here:
J
still better than spending big bucks for the other one.
I don't get where the "kind of, not really" comes in, if he got the OEM bracket to work and is working still
Looks like he was able to REUSE THE STOCK LS1 ALTERNATOR BRACKET to me in the pics posted in the linked thread.
A few minutes of thinking and fabbing and you can reuse your stock bracket
I'm sure I could whip that up in no time, hell the bracket I have on my car now took me all of two hours to get all the pieces and parts for after we got the alternator in position.
I've also remember seeing kurt from W2W fame reuse the stock alternator bracket mounted up top as well.
I have a set of C6 manifolds that I plan on using for my 5.3 turbo build.. Should I use them both or c6 on the passenger side and the truck manifold on the drivers?
The reason I ask is because I see a lot of HP being made out of the truck manifolds, and i'm wondering... Is there any extra to be gained by using c6 manifolds or would it be minimal and mainly done for clearance issues?
Where do you guys think would be the best spot to mount a t66 with the pass. c6 manifold and drivers truck manifold? Most setups I've seen have them mounted right in front of the motor.
