What exhaust should I use while using the APS kit?
What kind of exhaust should I do while using the 427 APS kit on either a 408 or 427 motor? This is a street car. I was thinking of running a 12"inch pipe off of each turbo and then a bullet muffler with it dumped. Or just running a 12"inch pipe and dumped (no muffler), or true duels. Is there a power diff between these three or any other set up. Pros and cons about each set up would help. I want it LOUD. I will have a lopey cam. I always loved the way my true duels w/ OR X pipe sounded. So I would like it as loud as I can get it. Thank you. If you have video clips or pictures that would be great
Aps
im going with not the best idea because being a turbo car its going to run alittle richer on the fuel side and all of that **** coming out would end up on your wheels and the side of the car. and that would just suck to clean off all the time or even hurt your paint
just my 2 cents guys
Turbos can quiet up the sound some but I like to have the best of both worlds. I would run either just ypipe into decent catback and electric cutout or run true duals all the way out to the back with mufflers. I would then get two electric cutouts for the true duals. Then you can open the cutouts as they are variable from open to closed when you want loud. And close them when you want to be more invisible to say cops and your neighbors and maybe play the stealth thing to other potential adversaries.
A super loud car gets old quick. And not every place puts up with them. With the cutout open you can hear the turbos spool up much better.With the cutout closed they are a lot quieter.
Sts runs no muffler at all on their system of course. Mostly personal taste.
Okay, if I need a little back pressure then will the pipe off the turbo with a bullet muffler w/ dumped be ok? Yes or No? What about these two exhaust set ups? Use true duels with OR X pipe w/ bullet muffler or true duels w/OR X pipe w/no mufflers which would be louder between the true duel set up? Being "To Loud" is not a issue. I want it to loud. I have a stroker with 3inch true duels OR X pipe and it is loud as ****. I love it when people roll the windows up. It is a street car but I only drive it on wkends or when I go to the street races. So the three choices I have are real true duel off the turbos w/ mufflers, duels w/X pipe and mufflers or duels w/X pipe and no muffers. I think duels off the turbos will be louder and better flowing, but is it enough back pressure?
Not sure why you would bother with going to true duals as said you can just put electric cutouts pre ypipe and run hooker or kooks ypipe into stock or other catback and have best of both worlds. You can be quiet when you want ,if you want and there are times you should want unless the police in Texas are that lenient but what if you take it to other states?The whole point of a turbo build up is the car should stay very streetable. A kitten off boost and a tiger on boost. My cam sounds near stock.
My exhaust with cutout closed is pretty darn quiet. You can not hear the turbos spool that much with cutout closed. You can not hear the blows off that much if you dont put it into boost and you don't hardly need to put it into boost just driving around town. A built 408 is no slouch even off boost.
But open the cutout and then you can hear it spool much better. Best of both worlds I think and electric cutouts are pretty cheap.
A turbo car is not going to be as loud as NA the turbos will act as muffers but my car still seems pretty darn loud with open cutout. I just have single and it at least least cuts down on the rattles and resonance by moving the exhaust back to under the passenger seat area when cutout is open.
Also if you are into street racing then its much sneakier to be able to make your car quiet the aps kit is very sneaky with nothing showing other than the intercooler neck.
With open exhaust people will hear you coming from miles away! Course you have some really loud blow offs now too but if you keep it out of boost they won't be that loud of course.
I didn't go for the stealth much as said have my emblems and liscence plate but not into street racing. At least not in city limits. Its treated like first degree murder where I live. So only be playing out of town and then only on like sunday mornings on nice likely double lane highways. A 1000 or so rwhp car is not going to exactly be that easy to keep straight. You may also want to look into variable traction control that I mentioned and for sure you will need some et street radials or m and h street radials doubtful nittos will do the job at your planned power levels.
Try a 12" Pipe dumped, no muffler, if you want loud. The turbos quiet the exhaust down so its still going to be loud, but NOT like your NA setup with open headers loud. I know on my twin turbo car, with open DPs, those turbos sound freaking insane. You wont stop smiling.
I don't think turbos need any backpressure ,sts has no muffler behind hit seems to work fine. I wasn't planning on running anything on my 91 talon race car other than just a long downpipe to about mid car..no muffler.
For sure remember you will need tuning on this TT car as well. Timing and AFR have to be brought down a lot from NA as well and you will pretty much need to go to 2 or 3 bar speed density.
