Question on APS power output in 2 different cars
Looking at their website a T/A with full exhaust at 7 PSI of boost is making 500 to the rears.
While a C5 Z06 is making almost 600 and it has stock exhaust.
I know it's an LS6 engine in it. But would a set of heads, and an LS6 intake bump up my number THAT much in my LS1?
That engine was pooched and their dyno is not dynojet and reads likely 20 % or something lower than a dynojet. There are lots of dynos on this forum if you search.
But also the better flowing your heads and cam and exhaust and all that are, the more power you will make at lower boost levels.
And yes, a better flowing exhaust and intake setup in a turbo car is going to make a world of difference. True duals for teh win =)
Here is a vette with similar engine mods to me..same cam and same heads I have.
Some numbers..
e beauty about turbos is that you can adjust the Hp with a touch of a button on the eboost2 controller.
I have the car tuned by one of the best tuners in the country.
here are the Hp setting:
1.606rwhp -640trq - 7.6 psi. 91 pump gas ( my wife drives the car with no problems
2.656rwhp -670trq 9.0 psi
3.707rwhp -773trq 11.6psi
4.736rwhp -812trq 13. psi
car makes 735rwhp(over 840 HP at the crank) on 13psi 812rwtrq(over 900 TRQ at the crank) ..car is a beast. will do the 1/4 LOW 10'S AND over 138+ mph.
condition is 8.5 /10 (its an 2002)
Here is the list of mods:
I just had a wideband installed- 250.00 plus install
( so the picture with the gauges has a wideband instead of the second boost gauge.)
Everything is done RIGHT - no corners cut!!
L.A.P.D did the install and they have done over 50 APS cars.
car has 35,500 miles and only aprox 2,000 miles on new Lingenfelter engine
2002 z06 red/black interior
APS twin turbos- $7995.00
LPE 255 fuel pump -$285.00
A&A return fuel system with a 340 secondary pump (can handle 900rwhp+) $1100.00
motrons 60 pound injectors -$499.00
magnavolt BAP-$220.00
Mcleod twin disc clutch rated at 1295rtq-$1301.00
eboost2 boost controller-$499.00
ALKY control methanol injection-$499.00
c5 black motorsports rims( i have the original stock rims , i will include with the car) $799.00
custom ART 3 inch exhaust with magnaflow mufflers $1400.00
SD 2 bar tune(you can drive the car anywhere) $800.00
lingenfelter output shafts on both sides - $999.00
brembo slotted front and back rotors /hawk pads- $520.00
steel braided brake lines
upgrades Steel BOV-$300.00
AFR 225CC heads with dual extreme springs-$2475.00
from
403 lingenfelter forged (can handle 1000rwhp)-6340.00 (i have receipt)
LPE cam LS1-GT7 208 / 230 .554" / .546" 1.7 ratio 121 (idols like stock)
Clevite Tri-Armor Coated Rod & Main Bearings
GM LS2 aluminum block - 4.0050" bore
Water jacket plugs, oil galley & cam bearings
Manley forged aluminum pistons
custom turbo Seal Rings
Manley H Beam 4340 forged steel connecting rods - 6.125
Callies LS2 4340 forged steel crankshaft
Speed Pro heavy duty rod bearings
Speed Pro heavy duty main bearings
GM High Volume Oil Pump
GM Hydraulic roller lifters
Competition Cams .080 Pushrods
Some numbers..
from
