blow up my motor, pics inside
Old 03-22-2009, 06:37 PM
eviltwin_1987's Avatar
Default blow up my motor, pics inside
this is an 85,000 mile stock lq4. i guess it didnt like 9 psi.
number 5
number 7
number 7 cylinder
bare block ready for the machine shop
here is one run before it went, through a 4l80e and a slipping t-case
new motor will be stock crank, mahle pistons, eagle rods, arp head and main studs, and more boost.
Old 03-22-2009, 06:42 PM
F-BodyGuy98's Avatar
i like that, 500+ hp and 500+tq...before it whent...the new motor should be beast...good luck man
Old 03-22-2009, 07:08 PM
wbwhiteboy's Avatar
That engine should have easily held that power. Must have gotten to hot and lean.
Old 03-22-2009, 07:17 PM
theblur98ss's Avatar
I love carnage pics...as long as they're not mine. Good luck with the new build
Old 03-22-2009, 08:35 PM
Reject's Avatar
damn that sucks! i'm at 16 pounds on my stock ls1 block with 88k miles on it!!
Old 03-22-2009, 08:38 PM
HUNTER02SS's Avatar
The one pic of the melted piston say's it's a to lean to me.
Old 03-22-2009, 08:42 PM
03tahoe22's Avatar
Wow that makes me cringe knowing im running 11psi and about to hit it with a 75hp wet shot..... How much can these engines take?
Old 03-22-2009, 08:49 PM
camarols1's Avatar
Much more than 500rwp.
The Baker crew have put up insane numbers on stock long blocks.
You just have to tune on the safe side, and run a bunch of meth and/or GOOD fuel to prevent detonation.
750HP can be achieved on race fuel and meth.
Old 03-22-2009, 08:57 PM
no meth on crappy CA 91 pump gas. there was oil blowing out the exhaust that was screwing up the afr reading, i picked up the motor used, the bottom end was very extremely dirty and there was fine metal shavings in the oil. it was just a ticking time bomb. but im not going to lie. i dont know much about this stuff.
Old 03-22-2009, 09:02 PM
Gordon0652's Avatar
Stock Block AND Internals?
Old 03-22-2009, 09:23 PM
could my piston melt like that because after it went the motor was idling for a while and i drove it around the parking lot on to a trailer and then off the trailer into the garage
Old 03-22-2009, 09:58 PM
tylert14's Avatar
Looks like she was detonating. Better fix that tune or you're new pistons will look the same! I'm rebuilding a 4g63 DSM engine at work that was detonating and the #1 piston looks identical. He drove it a few miles back to his house with a hole in his piston! lol
Old 03-22-2009, 10:34 PM
goturgoat's Avatar
piston looks like it chipped due to a lean condition. tops of the pistons were extremely clean looking, showing a lack of fuel. did you upgrade your pump and injectors at a minimum? maybe on the rebuild a wideband would help out on the tuning, if you did it yourself. what did the plugs look like?
Old 03-22-2009, 10:46 PM
crzytown69's Avatar
damn thats sick gl with the build
Old 03-22-2009, 11:49 PM
JMBLOWNWS6's Avatar
Originally Posted by eviltwin_1987
there was oil blowing out the exhaust that was screwing up the afr reading, .
Exactly what I was going to say!!! At least you understand.
Old 03-23-2009, 12:01 AM
THENASCAR's Avatar
that sucks to hear but those motors can handle alot more than that. definatly a tuning problem and the oil coming out of the exhaust doesnt help lol!
Old 03-23-2009, 11:45 AM
98BlkFormula's Avatar
wtf all that with only 9 psi?!! and reject wtf 16 psi?!! lol
Old 03-23-2009, 12:03 PM
Reject's Avatar
lol yeah but it's only on a tc76f1 turbo. i cant wait to order a meth kit hehe ^_^
Old 03-23-2009, 06:40 PM
jg04222's Avatar
I'm with this guy. one of the primary spots detonation attacks is the ring lands, and yours look pretty mangled.
Old 03-23-2009, 06:45 PM
ttranssam's Avatar
ouch...u would think they can hold a little more then that
Quick Reply: blow up my motor, pics inside
